![]() Join Date: Sep 2007
air ride set help
I purchased the dominator 2600 bags that were being offered on the site here and dont know what else I need to purchase. Heres my idea of what I want
* these will be installed in my 67 long bed in the rear only. (coil springs origionally) * I did purchase the mount plates * I know I need a compressor but how do I know which one to buy? * I want to do quick fills so I guess Ill need a small tank too? * Im not interested in the self leveling but I want to control the air intake and release from the cab (and I want a guage) what do I need? single or duals? * I also want both bags equal at all times so do I just run a "t" fitting? *What am I not thinking of ![]() Thanks guys Mike
1967custom |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: air ride set help
You need to run 4 valves total. 2 fills and 2 dumps. You need to keep the 2 rear bags on separate lines. This way the air will not transfer from side to side when you go around corners. One "dual needle" guage should monitor both bags.
Bigger compressor and bigger tank equals quicker lift times. Buy the biggest you can afford.
thats what I needed to know. so are all valves the same then? or are there certain valves for each job? (dump and fill)
1967custom |
same
If you are just baggn the back you shouldn't have to have seperate valves. The front suspension will stop the bodyroll. You can just put a T between them and when you air them up they will be the same pressure. If you bag the front you will need to seperate the bags but not on the back. I do agree with the bigger the tank and air lines the faster it will respond. I would go with 3/8" air lines b/c the 1/4" are slow and the 1/2" are so fast they are hard to control. I have put all 3 on trucks and the 3/8" is definately the way to go.
you also don't need mounting brackets ... drill a couple holes and bolt it up where the coil spring once sat.
ok so thats the 3rd time I heard I could use t fitting so that sounds good to me, I was wondering why I needed the brackets if I was getting rid of the springs.
The bags have 1/2" ports in the bag. are there reducers available to run 3/8" lines? for tanks, How many ports do I need if Im just running the rears with a t fitting? Im figuring 1 inlet port, 1 pressure switch, 1 guage and 2 air lines or 1 air line? Or do I hook up the guage to the valves? sorry but Im a newbie with the aride system
1967custom Last edited by michael bustamante; 05-15-2009 at 11:25 AM. |
Sofa King Crazy!!
Hey Micheal, I will get the photos you requested of the rear install on the bags tomorrow and post em for ya.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#9 | |
quick question, for just the 2 bags, is 150 psi too much?
1967custom |
#10 | |
Sofa King Crazy!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 05-18-2009 at 02:31 PM. |
5 times huh? got it, thanks again!!
And you know, this was only going to be camping truck!!
1967custom |
![]() Join Date: Apr 2005
Michael,
Here's a link to a thread when I bagged my suburban: Front - http://67-72chevytrucks.com/vboard/s...d.php?t=174330 Rear - http://67-72chevytrucks.com/vboard/s...d.php?t=162718
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#13 |
someday it will be done!
I built my own tanks,and I've installed ports for what you've mentioned as well as a port for a pop off valve,and a port that will run to a female quick connector in the cab so I can run a hose to fill tires and operate small air tools.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
