Old 05-14-2009, 06:48 PM   #1
Big Fenders
Rear Mounted Gas Tank
I know this topic has been beat to death but here's what I did. My truck is a 63 1/2 ton step side. Gas tank that I used is a 16 Gallon Mustang tank. Lowere frame rails had to be cut 1 1/2 inches off each side to allow tank to slide in. I used 1 inch square stock screwed to the top frame rail and secured the tank to that with straps...see photo. All contact areas were rubber covered. Hope this helps..
Bob
Big Fenders is offline   Reply With Quote
Old 05-14-2009, 07:08 PM   #2
daverod
SSN 706
daverod's Avatar
Re: Rear Mounted Gas Tank
What year of Mustang was it Bob? Looks new.
daverod is offline   Reply With Quote
Old 05-14-2009, 08:51 PM   #3
Big Fenders
It is new...recent purchase 67 -69 Mustang tank.
Bob
Old 05-14-2009, 11:11 PM   #4
bubba327
HOW long until spring??
bubba327's Avatar
Looks good . What are you using for a sending unit? Will you fill through the bed floor or do you have room to turn it out and fill from outside the bed?
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 05-15-2009, 10:49 AM   #5
Big Fenders
Its a Ford sending unit modified to Chevy...No room to swing filler to the side so it will fill through the floor which will probably be diamond plate. I did the same with a 55 Chevy 1/2 ton ,Mustang tank and through the floor fill and was pleased with the results.
Bob
Old 05-15-2009, 11:31 AM   #6
protrash64
Resistance is Futile
protrash64's Avatar
Good idea and it looks slick...almost like it should have been there from the factory.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-15-2009, 03:18 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Rear Mounted Gas Tank
Nice!!!!!!!!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-15-2009, 08:43 PM   #8
karlbenz
Looks great
karlbenz is offline   Reply With Quote
