Old 05-14-2009, 07:58 PM   #1
crazyredneck
steel floor to wood floor?
can you change a bed that has a regular steel floor over to a wood floor?
crazyredneck is offline   Reply With Quote
Old 05-14-2009, 08:00 PM   #2
weircc
weircc's Avatar
Re: steel floor to wood floor?
you can but im sure its alot of work they also make a kit for over the steel but pricey hope this helps
weircc is offline   Reply With Quote
Old 05-14-2009, 08:56 PM   #3
Sammy
Yes. I have also seen a few that mounted the wood bed on top of the steel floor too. Didn't look too bad either. Like said above someone makes a kit to do just that, though pricy. I think to convert you need a new head board, and all the under bed braces replaced.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-14-2009, 10:01 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mar-K has everything you need.
Old 05-15-2009, 07:22 AM   #5
69c10step
69c10step's Avatar
Check here for the Mar-K list http://www.mar-k.com/steel_floor_to_wood_bed.html
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 05-15-2009, 10:55 AM   #6
coggonobrien
long box or short? I have a long box wood bed that is in pretty good shape if you are interested. The crossmembers and bed front should be the only significant differances. i would be willing to trade those pieces from mine for your steel bed front if its in good shape. we just each pay the shipping for the parts we are receiving.
David
coggonobrien is offline   Reply With Quote
Old 05-15-2009, 11:07 AM   #7
jb4short
Damn Yankee
jb4short's Avatar
Mar-K has a kit....great stuff
jb4short is offline   Reply With Quote
Old 05-15-2009, 06:36 PM   #8
SBC
SBC's Avatar
I will be doing this conversion soon and from what ive seen Mar-K is the way to go.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 05-15-2009, 11:25 PM   #9
420am
420am's Avatar
Bruce Horkey's Showdeck
http://www.horkeyswoodandparts.com/page2.html
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 05-16-2009, 12:32 AM   #10
highperf4x4
In case nobody has mentioned it yet........ Mar-K
highperf4x4 is offline   Reply With Quote
