Old 05-14-2009, 11:15 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Front sway bar for rear?
Will a front sway bar fit on the rear? What would need to be done to make it fit?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-14-2009, 11:19 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Front sway bar for rear?
No it won't fit. It can be made to fit with the proper tools....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-14-2009, 11:22 PM   #3
thirdstreettito
Resident of Here
Aww. What rear sway bars will fit?
~Bradley~
Miss having a truck
Old 05-15-2009, 03:17 AM   #4
79blazer
79blazer's Avatar
Now this may be useless... but I've seen in the you-pull-its, a rear sway bar (on I believe old fords) that clamp to the axle tube and the ends that mount to the frame by simply drilling a hole. Just a thought.
There's always the stock rear sway sometimes found on duallys.
One way to fool a vehicle with poor suspension geometry to handle more like a sports car is to stiffen the suspension. Try 3/4 ton springs.
Good shocks would help sway too.
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 05-15-2009, 08:07 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Look for one under a Suburban.
Articles-
"Refining Sierra"
Old 05-15-2009, 11:12 AM   #6
bigblock73
yeller
bigblock73's Avatar
It might bolt up if this is your truck.
bigblock73 is offline   Reply With Quote
Old 05-15-2009, 03:21 PM   #7
thirdstreettito
Resident of Here
Thanks guys, I'll have to look at the burbs and duallys nearby.
~Bradley~
Miss having a truck
Old 05-15-2009, 10:02 PM   #8
f.monroe
f.monroe's Avatar
I posted a while back that I came across a truck that had a sway bar from a mid 70's camaro on the rear of the truck . It was a front sway bar from the Camaro .He did some fabbing of the mounts like muffler clamps holding the factory frame mounts at the axle and he used the sway bar links from the Camaro's sway bar to control arms to mount to the frame . It actually looked factory . He mounted his where the dip in the bar went right over the pinion and it didnt hang below the rear axle . Looked factory .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
