Old 05-15-2009, 10:37 AM   #1
manimal
manimal's Avatar
Turning radius??
My '84 1 ton Crewcab...single rear wheel....makes turns like a barge. Would changing the steering box to a quicker ratio help that out? Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-15-2009, 12:42 PM   #2
79 silverado
Re: Turning radius??
Not in the way I think you are looking for... practical real world example of why it feels like a slower turn is because of the very long wheelbase goes a little like this...
pretend this is a normal truck wheel base:
o---o
well, the arc it would sweep through in a turn would be from drawing a line to where it turns to:
o---o
l
o
connect those outer two o's
well the longer wheelbase has more distance to cover
o-------o
l
l
l
o
see how that connecting line is longer? that means that even turning at the same speed, you have more distance to cover, and thus it seems like a lower response time... thus that barge effect you speak of.
Getting the steering gear to respond quicker doesn't really change the amount of area you need to sweep through before those rear wheels point in the new direction, so, you will always experience a good part of that barge feeling, its what comes from driving one of the big boys....
79 silverado is offline   Reply With Quote
Old 05-15-2009, 01:24 PM   #3
Prerunner1982
Prerunner1982's Avatar
The only real option here is to shorten the wheelbase or install a rear steering axle.
I have been real suprised how well my Jeep XJ turns. My wifes s10 Blazer has a much worse turning radius than the Jeep.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-15-2009, 01:52 PM   #4
78 Chevyrado
Sounds like a denali pickup rear-steer swap is in order here...
78 Chevyrado is offline   Reply With Quote
Old 05-15-2009, 02:40 PM   #5
Prerunner1982
Just for giggles I did a bit of research and compared wheelbases to turning radius of a few vehicles.
Make/model wheelbase turning radius
99 Jeep Cherokee 101" 17.9'
09 Ford Escape 103" 18.3'
00 Chevy Suburba 130" 21.7'
05 Chevy Cavalier 104" 17.8'
10 Ford Edge 110" 18.8'
01 Hummer 130" 26.5'
91 CC Chevy 164.5"
I couldnt find the radius of a CC but just looking at the wheelbase you can see why it turns like a barge. It has almost 3' on the suburban and excursion which have a 21.7' and 26.5' turning radius.
Jon
Oklahoma Roll Call
Old 05-15-2009, 03:13 PM   #6
pig rig
pig rig's Avatar
ha ha yea, the crew cabs take a wide birth to get them turned about
and once you lower it down it feels like it takes more room to get it docked
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 05-16-2009, 12:28 AM   #7
88 Dippy
88 Dippy's Avatar
man my truck feels like a bardg i am glad it's only a reg cab long bed
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 05-16-2009, 01:59 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
my regular cab short bed feels like a battle ship trying to make u turns and sharp turns usually I'll be patient I'll drive up on the side walk a little or if there a parking lot I'll go that way and turn at the closest exits, and if I'm hurry I'll get on it a fish tail like crazy
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-16-2009, 02:27 AM   #9
88 Dippy
88 Dippy's Avatar
if the truck had the balls to fish tail i would but sadly they seam to be missing
