Old 05-15-2009, 01:39 PM   #1
69heavychevy
69heavychevy's Avatar
need help getting the 350 up n running
my friend and i got through installing a brand new gm crate motor on his 72. but for some reason we cant get it to run right. when he puts in drive and hits the pedal it sputter and backfire through the carb. but i ease onto the pedal it will accelerate fine till 20mph or so and then start backfiring. we've checked and double checked wires, vacuum hoses, timing, and just about everything else. like i said he has a brand new gm crate motor (260hp i believe) 1-5/8 long tube headers (open, no exhaust), edelbrock performer rpm, edelbrock 1406 carb, msd street fire dizzy set to 8 degrees, th400 with posi 3.08. in park we can mash the pedal all day with no sputtering or backfire, but as soon as it goes into gear it starts acting up. any idea of what the problem could, thanks in advance for your help.
69heavychevy is offline   Reply With Quote
Old 05-15-2009, 02:47 PM   #2
nsuengineer06
nsuengineer06's Avatar
Re: need help getting the 350 up n running
I am no expert on the matter, but sounds to me like timing and/or carb tuning. If it's not the timing directly, you may have a crack or small hole in the vacuum advance (if so equipped). Hopefully someone with a lil more knowledge will chime in soon for ya.. Best of luck!
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 05-15-2009, 03:30 PM   #3
americanmusc1e
americanmusc1e's Avatar
you don't have any vacuum leaks do you????
and you do have the vacuum advance hooked to ported vacuum (almost no vacuum at idle--vacuum ocurs at higher rpm)???
put a vacuum guage on it if you have one
I doubt its in the carb, its got to be ignition, did you run a full 12v to the dizzy or use the factory resistor wire on the dizzy????
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 05-15-2009, 03:48 PM   #4
cdowns
cdowns's Avatar
did you make sure it was at TDC on THE COMPRESSION STROKE when installing dizzy?
Old 05-15-2009, 03:52 PM   #5
americanmusc1e
I thought about that, but I don't think it'll run like that, just backfire when your trying to start it
-- Josh
Old 05-15-2009, 07:13 PM   #6
Irishpilot
I'm also leaning towards TDC issue. Double check to make sure the RRs weren't set off of the #6 piston. If you are sure they were set off of #1 TDC then I would still reset the valve-lash.
This comes down to a process of elimination.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 05-16-2009, 02:36 AM   #7
69heavychevy
yea we made sure dizzy was installed at tdc on #1, n the vacuum advanced is hooked up to ported vacuum nipple on the carb (the one on pass side). will a bad modulator cause any of these symptoms?? the dizzy does have adjustable vacuum advanced so we will probably start messing with that next.
