Old 05-15-2009, 01:43 PM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Leaking rear axle on an Eaton- help
My 71 C20 is leaking gear oil from the back of the RR wheel. This has an Eaton rear with the big salad bowl cover. How hard is it to change these?
I looked on Autozones website and they list H052 or Spicer 60. Which one is mine anyway?
Thanks for any help,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-15-2009, 03:21 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Leaking rear axle on an Eaton- help
Ho52
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-15-2009, 03:41 PM   #3
Elephanthead
Easy to fix. Drive down to Midas and tell them to change it!
Elephanthead is offline   Reply With Quote
Old 05-15-2009, 04:45 PM   #4
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
screw that big heavy chunk of iron and put in a 12 bolt! you can get any parts you would ever need for that then. but thats just me. where exactly is it coming from?
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 05-15-2009, 05:03 PM   #5
bobs409
bobs409's Avatar
It's coming out from inside the brake drum.
Bob
Old 05-15-2009, 09:29 PM   #6
hicktownhotrodder
Rollin Coal
ha well i am going to join you! after i made my reply about this, my truck must have been listening. i drove 4 miles to work and it was spewing oil on the outside of the drum. are you sure its rearend oil and not brake fluid? cause mine does that too
God-Made-Chevy
Old 05-15-2009, 10:54 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have the special socket to remove the hub assembly, then it is a simple job. Pull hub, remove seal, drive new one in, clean drum and shoes real good and reasemble.
Old 05-16-2009, 01:22 AM   #8
sleepertruck72
sleepertruck72's Avatar
Its not that hard really. Like LHM said get the special socket, it will make it easy. My C20 had the same problem, but I have the Dana 60. I imagine it should be really similar. I also had wheel cylinders leaking so I rebuilt those. You may want to Check them out while youre at it
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 05-16-2009, 04:54 AM   #9
bobs409
bobs409's Avatar
Thanks guys. It's definetly gear oil, no mistaking that smell! lol
I already have the socket. I needed that when I replaced the entire rear brake system, everythng but the backing plates! On a 3/4 ton, that means: $$$
I sure wish I replaced the $5.99 dollar seals while I was in there!
I know what I'm doing today.
Bob
Old 05-16-2009, 06:13 AM   #10
Longhorn Man
you should replace the seal whenever you take the hub off.
Old 05-16-2009, 10:19 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
What size is that socket?
Beat it to fit,
Old 05-16-2009, 01:02 PM   #12
bobs409
bobs409's Avatar
Wow, that sucker was really in there! It took about 20 minutes to pry and rip it out. Even to install the new one was so tight, I used my shop press rather than trying to hammer it in.
One thing is for sure, my RR wheel well or exhaust pipe won't rust for a long time! That gear oil goes everywhere!
If I had known about this seal, I would have replaced it earlier. I was thinking an axle seal was behind the backing plate for some reason. I never even noticed them before.
Hope that cures the problem... (test drive to be done yet)
Bob
Old 05-16-2009, 09:26 PM   #13
Elephanthead
I used a jack handle and just pounded them out from behind, there is a seal removal tool though that has a pointy spike to get um out. I did change mine when I did the brakes, you should also lube them up before you put the drum back on.
Old 05-17-2009, 11:14 AM   #14
Longhorn Man
Elephanthead is right, and I forgot to mention that the other day.
When slipping the hub on, it's always a good idea to dip your finger in some clean smelly gear oil and coat the hole of the seal so it'll slide onto the spindle easy and with no damage.
Old 05-17-2009, 02:44 PM   #15
bobs409
bobs409's Avatar
I must have done it right, no leaks!
On to the next project...
Bob
Old 05-17-2009, 02:58 PM   #16
Sinister
Between Trucks...
Sinister's Avatar
Hey bobs409, you wouldn't happen to know the size of the spindle nut socket for the hub would you?
Beat it to fit,
