Old 05-15-2009, 02:25 PM   #1
JimmyFloyd
1970 SM465 2wd usable in a 4x4?
Will a SM465 from a 2wd be usable in a 4x4? I am looking to get one incase the one in my blazer goes, but it's from a 2wd.
Also, how hard is it to remove? I've never removed one before.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-15-2009, 05:06 PM   #2
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
Re: 1970 SM465 2wd usable in a 4x4?
ill make you a deal... if you have the right adapters to go to the T-case then it should. GM used the 465 from the factory. look for one with the T-case stilll on it
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 05-15-2009, 05:36 PM   #3
Ace in the hole
The problem is that the 2wd trans had a different output shaft on it than the 4wd. IIRC the 2wd has a 35 spline and the 4wd has a 10 spline output. Not hard to change if you have the know how.
Some good info here- http://www.4wheeloffroad.com/brandpa...ild/index.html
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 05-16-2009, 08:05 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
You could also go to a divorced transfer case but that would be a lot of work - I'd just get a 4wd SM465 - they are cheap and pretty plentiful.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-16-2009, 04:26 PM   #5
JimmyFloyd
yeah, I was looking at this one because it's in a C20 here and would have only been $50. Mine is in good shape, but it'd never hurt to have a spare. I'll just wait a bit and see if I can find a 4x4 one.
Old 05-16-2009, 05:19 PM   #6
Mike C
Mike C's Avatar
$50 is a great deal. I'd buy it for that. But if you make even minor attempts at maintenance, it will last just about forever. My Jimmy's SM465 has more than 350,000 miles on it now. I've changed the fluid once and the clutch once. It's pretty hard to tear one up in a pickup truck or SUV. Plenty of 2 1/2 ton trucks, school buses and UPS trucks use them so you can see what they can take.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
