05-15-2009, 03:03 PM | #1 |
Redefining LowBudget
what shock ( for the millionth time??)
I bagged my truck and got the rear all set up just don't know what shock to run on the front...bagged with cups....it need to be 9" closed and 13" open
help I want to drive this thing but with no shocks it feels like a sponge!!!!! Jeff ps I tried search but couldn't find anything
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
05-15-2009, 03:27 PM | #2 |
Seņor Member
Re: what shock ( for the millionth time??)
I tried search and got 100 hits, which is the maximum it will return, meaning there were likely more threads.
http://www.myattitudesucks.com/truck/shocks.xls
05-18-2009, 02:36 PM | #3 |
3DrDwn--the 'burb not the band
13-9= 4" travel.....
your bags should be giving more than that. Have you relocated your upper mount to allow for a longer shock? I'll look for the part# for mine but without actually putting a tape on them I'm pretty sure I have more travel than that. are you runnin eyes top and bottom or a stud type upper mount? I can check my x-reference book and see if I can find something for you. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
05-18-2009, 05:24 PM | #4 |
thanx I just checked again and 8.5 would stop me from bottoming them and 13 is as high as I can raise it...my shocks are in the stock location with eyes at both ends, I dont want to relocate unless I have to....I would even concider cutting the top the shock eye off then clipping and inch off the rod and rewelding them first
xxl I down loaded your spread sheet but do not have excel and can't open it but thanx |
05-19-2009, 01:03 PM | #5 | |
86 C10
sorry for thread jack!!!
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
05-19-2009, 02:58 PM | #6 |
Seņor Member
See attached PDF. Also note, the cross pin and cantilever mounts can be adapted to loop very easily by simply pushing out the metal parts and replacing with an appropriately sized bushing. Find the shock that meets your needs in terms of compression, extension, and damping first. Then go for eyelet info.
05-19-2009, 09:05 PM | #7 |
thanx for making it PFD but only page 5 is there showing the specs for the ends??
05-20-2009, 06:05 AM | #8 | |
Old Heap Driver
Oh BTW, PLEASE DON'T do any welding on shocks!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
05-20-2009, 10:43 AM | #9 |
Junior Member
First off.... you do NOT want your shocks to bottom out first. You will definitely be replacing the shock mounts if that happens. You want it to bottom out on the bag or the bumpstops first. Second, it is very likely that you will only need a 3.5 to a 4" stroke shock. With the front suspension having a ratio close to a 2:1... that means you will end up with close to 7-8" of travel at the wheel.
05-20-2009, 01:58 PM | #10 | ||
Seņor Member
Microsoft has a free downloadable Excel viewer, Google Apps has one as well. You've got to do some of the work here. I've provided you all the info you need... I can't hold the spoon too. *sigh*
09-15-2009, 03:30 PM | #11 |
Seņor Member
bump
09-15-2009, 05:52 PM | #12 |
not sure why the bump but
I ended up useing Monroe 5752 like was suggested by S10fan I have a few thousand miles on them and all is well Thanx |
