Old 05-15-2009, 05:33 PM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Stock double hump X-member and 700r4.
Anyone running a stock double hump transmission crossmember with a 700r4? Seems with mine the x-member is to wide to fit in the frame and line up with the bolt holes. If I move the x-member toward the rear differential it seems to fit much better. In that position the transmission mount doesn't bolt up to the x-member because it is moved back.
So has anyone ran into this problem? I'm thinking about making a plate to bolt to the transmission mount. It will allow the x-member to be rearward and still work. It seems like that would work but I'm not sure about strength.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
