FS swap question
have two burbs....one is a 94 2500 4wd that I just love but kind of hate the front suspension on it and would prefer a more simple setup. I have a 1991 2500 4wd burb that has a nice independant setup....can I swap? If so, would it be legal?
Re: FS swap question
oops....the 94 has the independant setup and the 91 has the solid axle.
guys do the solid axle swap but i'm sure it's not easy. Is your transfer case a driver or pass side drop? Most switched to driver with IFS I thought and were pass side with solid axles.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Nothing illegal about it, just be sure and do it right the first time.
![]() Mikes correct about the drop but you can use a furd drivers drop t-case to get it done no prob. |
thanks for your help guys....but I've decided to pull the engine, tranny, A/C system, hydroboost, and braking system from the 94 and put some of it into the 1991. I'm having door problems and rear end issues now on the 94. Anti-lock brakes just went out and the transfer case needs to be replaced. The 91 has a rebuilt 3/4 rear end with a 4 inch lift and 1Ton springs. Has a nice Dana solid axle setup in the front as well. Also has a 97 vortec 454 with under 70,000 miles. I'm hoping to find a way to make that work...if not I'll use the 94 TBI 454 engine. It also comes with a brand new flowmaster exhaust and cat setup. Not to mention new 35 BF's on the 16.5 rims. Man... I don't know what I was thinking to not use this instead. Just one drawback....the rear seat doesn't have a drop for the legs. Oh well.....if the A/C is cold....the kids won't ***** too much.
