Old 12-30-2002, 12:44 AM   #1
dieselburban
suspenion lift
I have a 84 suburban 4x4 with a 6.2 liter diesel in her.I want to put a 6 or 8 inch suspension lift in it,I need to know what kind of modificatoins I will have to do such as will I have to lengthen the drive shafts,steering geometry,brake lines axle angles,etc.it is a half ton and I would like to put 35s or 38s under it.please help and be very informitive since I'm a shadetree mechanic thanks to all who reply.
dieselburban is offline   Reply With Quote
Old 12-30-2002, 01:08 PM   #2
Prerunner1982
Prerunner1982's Avatar
dieselburban, welcome to 67-72.. its a good site.. with a 6-8" suspension lift you will have to lengthen driveshaft, adjust linkages, correct steering geometry with a drop pitman arm (there are a few other ways as well)..i am certainly not trying to take anything away from this site, but you might consider taking a look at www.coloradok5.com. i think you will find the info you need there.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-30-2002, 05:22 PM   #3
chevy68388
king $h!t
chevy68388's Avatar
on my 87 i havent had to replace any thing beside the pit man arm if u run blocks in the rear the have the angel cut in them as for brake lines they come with a thing that puts them under the frame instead of throw the frame i have 9 inch lift but 3 of that is body
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 01-20-2003, 02:03 PM   #4
chevy lover
HMMMM Chevy
chevy lover's Avatar
I have An 82 gmc 4x4. I want to do a 4" lift. will I still need to change the pitman arm?
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
chevy lover is offline   Reply With Quote
Old 01-20-2003, 02:17 PM   #5
Mudder
Mudder's Avatar
Yes you need to put a dropped pitman arm on. If you dont your steering wont be right. And shocks. Theres lots of guys here than can help you with a lift. Myself I wouldn't go bigger than 35's with half tons, Burbs are pretty heavy. Theres a good chance you wont have to do anything to the shafts. Just wait and see.
Mudder is offline   Reply With Quote
Old 01-20-2003, 09:56 PM   #6
chevy lover
HMMMM Chevy
This truck is a half ton. it is also a 6.2 deisel. Is anyone familiar with these cause I want to get a little more get up and go out of it.
Mike
