Old 12-30-2002, 01:00 AM   #1
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Question Valve Cover Help
I got some new valve covers for Christmas and I have 3 holes in the covers. I have the PCV, and breather to go on the valve covers but I still have the one hole left. What needs to go there? Is there an oil cap that goes there? On the valve covers I have now I have the plain black ones that came on the ZZ4. I'm thinking a oil filler cap but want to make sure. They came with the 2 grommets made for the breather and PCV but nothing on the 3rd hole. Here's what they look like
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-30-2002, 01:06 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Brandon,
your valve covers are what I wish was made for non center bolt heads, three holes. I drilled another hole in one of my Billet Specialities valve covers. I wanted three holes and nobody makes them for regular heads.
Anyway, on mine, I have the two hole cover on the passenger side, with the one hole on the drivers side. The two hole has a breather in the rear hole, and a oil fill cap in the front one. Then the drivers cover (one hole) has the PCV in it.
I'm guessing it came with all three grommets, right? Just get a push in oil fill cap, which has the grommet built in. Don't put the baffle in the hole, but the other two needs baffles.
Also, nice valve covers. I wish they would make some like these to fit my heads. I would have already had them by now if they did.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-30-2002, 01:08 AM   #3
swervin ervin
Oops, sorry, need to read better. I seen you said it had two grommets. Just buy a push in oil fill cap. Billet Specialities makes some nice ones.
Mike
1985 Chevy C-10
Old 12-30-2002, 01:15 AM   #4
79BIG10
79BIG10's Avatar
Thanks Mike. Actually they only came with 2 grommets. The larger hole didn't come with one. I'm going order these hopefully soon. I don't like the looms I have now to fit on the new covers. Also I'll have to get a oil filler cap. Thanks for the info.
Old 12-30-2002, 02:01 AM   #5
86SILVERADO
86SILVERADO's Avatar
Hey mike, I am on a quest to find a set of covers with the oil filler hole. I won't rest until I find them.......
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 12-30-2002, 11:01 AM   #6
swervin ervin
Good luck. They simply don't make them in aluminum for old style heads. I found a set in some parts magazine, but damn, they were something like $250.00 or some such junk. And on top of that, they didn't look that great.
I have found them with 3 and 4 holes both in chrome steel, even have a set of the 4 holes I just took off.
What I did was buy Billet Specialities plain polished covers and drilled my other hole with a 1.25" hole saw. I had to put some tape behind the grommet to tighten it up a little because the hole needs to be 1.22" really. Works real good though and looks factory. I would have went with a design on them if it hadn't been for needing to drill this hole.
Mike
Old 12-30-2002, 01:08 PM   #7
chauffeur
[QUOTE]Originally posted by swervin ervin
[B]
What I did was buy Billet Specialities plain polished covers and ....
I just happen to have a brand new set of these looking for a new home. Really nice stuff. Ken
chauffeur is offline   Reply With Quote
Old 12-30-2002, 01:22 PM   #8
PHOENIX
chauffeur:
Check your private massages. I may buy them from you
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-30-2002, 05:54 PM   #9
racedvl
racedvl's Avatar
79BIG10, who makes those nice looking looms?
racedvl is offline   Reply With Quote
Old 12-30-2002, 09:46 PM   #10
86SILVERADO
A FELLOW RODILANDAH!! NO F'IN WAY! I have been thinking about posting a messsage asking if there was even anyone from freakin new england out there. No offense to you folks down south but us yankees got to stick together.
Ken, I don't think I am interested but if the folks at the parts shop screw up one more order...Thanks for the reply anyway.
You wouldn't by any strange chance have a 3/4 or 1 ton rear that you would want to swap for a 1/2 ton? just though I'd ask.
Norris
Old 12-31-2002, 12:18 AM   #11
79BIG10
79BIG10's Avatar
I found them here. http://www.made4uproducts.com They also have alot of other looms but these are the best ones I've found to show off the new valve covers. Looks like it will be awhile until I can buy them unless I get some $$$ soon.
Old 12-31-2002, 01:01 AM   #12
swervin ervin
Brandon, what are the part numbers for the whole kit you need for your valve covers? Is the ones in the photo above the ones you are thinking about getting? From what I read, it looks like the price is for one side. Is this right?
Let me know.
Mike
1985 Chevy C-10
Old 12-31-2002, 04:26 AM   #13
79BIG10
79BIG10's Avatar
Mike here's the numbers:
Center Bolt Aluminum Brackets Part # 50-82494 - Suggested Retail $22.15
Vertical Wire Loom Kit (Fits 7-8mm dia. Wire) Part # 50-756-__ - Suggested Retail $34.95 (in blank spot put color code)
The brackets (aluminum) are a package by itself then you buy the color looms. One package of each will do a complete engine.
Old 12-31-2002, 12:53 PM   #14
PHOENIX
Hey Mike how hard was it to drill a hole in those valve covers you bought (the plain cast aluminum ones from billet specialties)?
I'm up in the air right now about which to buy. I really really like the chevy script ones, but the plains are so much cheaper.
Old 12-31-2002, 01:22 PM   #15
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Damn B!! You got them!! Saweeeet!!
U SUCK!! haha
NIce!! I need to ask for them for my birthday. Those and the looms so I can show them off and then sell my covers and looms.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 12-31-2002, 01:25 PM   #16
LOHRTBT
LOHRTBT's Avatar
Also,...if you dont mind me asking where did they order from....was it a better price??? I need to tell people how much they are if they are gonna get them here before the 11th!! haha
~Dave~
Old 12-31-2002, 02:48 PM   #17
swervin ervin
Dayum Brandon. That is some high priced looms. But they do look fantastic. What color was you after?
Eddie,
I used a 1-1/4" hole saw. It has to be a good one, to cut the metal. You can't use the cheapos. It don't have to be one specifically for metal though. It wasn't hard at all, pretty easy really. I used my drill press so not to wobble out the hole.
Only thing is the 1.25" hole saw is well, .03" too big. The hole actually needs to be 1.22". What I did was use some electrical tape, cut into 3/8" or so wide strips, and wrap it aound the outside of the grommet, where it goes against the cover. About three wraps of this tightened it up just perfect. I used the Billet Specialities breather, PCV, and oil fill cap.
Mine works real well.
Old 12-31-2002, 09:43 PM   #18
neonlarry
neonlarry's Avatar
M/T valve covers have a space to put a breather and a oil fill cap on both sides if you want. You have to knock out the hole, but it actually has a place made for it.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-01-2003, 02:10 AM   #19
79BIG10
79BIG10's Avatar
Dave- LMAO!!! I sent the link to my mom of the Salle-Chevrolet's site. They're $100.00!!!! Yeah they went down on price from when we first pricing them. They're part number 141-130 here's the link http://www.sallee-chevrolet.com/Prof...ve_covers.html I'm trying to get my wife to spend an early anniversary present on the looms for me
Mike- Yeah they are expensive but I paid $40 on the looms I have now and not even come close the the looks of these new ones. If I can sweet talk the wife I'll try to get them ordered this week and have them on next week. I don't want to install the new valve covers without the new looms since the old ones may scratch them up. One the color I was thinking black but not sure yet. May take a poll on that this week
Old 01-01-2003, 11:41 AM   #20
swervin ervin
Brandon,
doing a quick search for places that sell these things cheaper, I found this one.
http://www.centuryperformance.com/de...d=MFY-50-82494
http://www.centuryperformance.com/de..._ID=MFY-50-756
Also, did you ever look at these?
http://www.centuryperformance.com/de..._ID=MFY-50-356
Old 01-02-2003, 12:33 AM   #21
swervin ervin
Brandon, you here?
Old 01-02-2003, 02:34 PM   #22
79BIG10
79BIG10's Avatar
Sorry Mike been hell at work Thanks for the heads up!!!! You just have made my day!! Looks like I'll get those like I wanted and have maybe enough for an extra chrome goodie Also I have seen those others but want to show off the covers as much as possible.
Old 01-02-2003, 02:35 PM   #23
LOHRTBT
LOHRTBT's Avatar
Thanks for the cheaper find Mike!!
~Dave~
Old 01-02-2003, 05:52 PM   #24
swervin ervin
See, I'm good for something besides just being pretty.
Old 01-02-2003, 06:41 PM   #25
LOHRTBT
LOHRTBT's Avatar
HHHHHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAAAAA HAHAHAHA!!
HAHAHA....HAHA...HA...OH MY.....OHHH.....OH. SIDE HURTING!! LOL :p :p :p :p :p :p :p
~Dave~
