1968 chevy 327 carb
Does anyone know where i can get a carb for my '68 c50? The thing is that it has to have the vaccum powered governer on it and no one seems to have one.
Re: 1968 chevy 327 carb
Do you have to have a governor?
Reason I ask is I have a 427 T.D.It had a huge Holley 4-barrel on it(with the governor under it) and leaked really bad.I just put a quadra-jet on it and it's running.But it's not in a big truck. Mike. ![]() |
I don't know much about needing the governer. I cut the line off of mine to see if it would run and it did but at a high idle and my dad said that doing that i would have a very high chance of burning a valve. Do you still have the 4bbl carb that you took off?
Yes,I do,but mine is a 427 engine and it won't run very well on your's even after a rebuild.I put a Holley back on mine(not a quadra-jet like I said above).It just sits on the floor in the shop when I run it.
Does your distributor have a vacuum advance?Mine doesn't.You may have to put one on it to make it run right without the governor. Mike. ![]() |
does anyone have any idea where i could get a new carb or somebody have one to sell? I'm desperate.
![]() Join Date: Feb 2001
This is just and idea...contact the Site Vendors and they might be able to give you some solid leads. Thats what I would do. Hope this helps. By the way...
![]() Here is a link to our Vendors...the three listed below is who I would start off with. Classic HeartBeat-WES GMCPauls-Paul Christian Classics-Tim Good Luck with your search. http://67-72chevytrucks.com/ By the way...if you become a Site Supporter you could post a WTB (Wanted To Buy) and there is a good chance you could pick one up at a very good price. Just an idea.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-19-2009 at 08:36 PM. |
