1967 c10 spring and shock set up
i have a 67 c10 and i recently purchased 3' lowered coil springs. i have 2.5 drop spindles and stock shocks. i removed the old coil springs which were poorly cut by the previous owner. i put the new coil springs in and they still dont fit quite right. my stepfather says that the shocks shouldnt be an issue because there should be some pressure on the springs without the shocks and that they should fit. i bought the springs from brotherstrucks.com
also anyone know the stock front spring height Last edited by slopesteez; 05-16-2009 at 02:09 PM. |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: 1967 c10 spring and shock set up
I'd Like to first say welcome to the board. I don't have an answer your question but would like to send it to the top. There's allot of years and knowledge with our board members. I'm sure you will have your question answered. Good Luck.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Three inch springs will fit loosly when the truck is jacked up with no weight on the suspension.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 05-16-2009 at 03:08 PM. |
tx firefighter----ya there is about a little less than an inch of travel. im worried that if im driving down the road and i hit a bump that i will damage my truck. it just seems like that they are too loose.
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
They will be loose when the truck is in the air with no weight on the suspension. Dont sweat it. Put it together and post some pics.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
