Old 05-16-2009, 04:44 PM   #1
mothertrucker424
mothertrucker424's Avatar
2wd to 4wd silverado
i have a 2wd 2000 silverado has anyone swaped in a solid axle i have looked and looked
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 05-16-2009, 05:13 PM   #2
Ace in the hole
Re: 2wd to 4wd silverado
I don't think that 2000 4x4 trucks had solid front axles. Not sure what year they stopped using them but the newer silverados are not solid front axle trucks.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 05-16-2009, 07:52 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
He was asking how to do a swap not if they still come from the factory with them.
Check out B&C offroad. They do a lot of straight axle swaps and lots of pics. It should be the same as olders trucks. You can also check out the 2wd to 4wd converts on this forum.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-16-2009, 08:54 PM   #4
Ace in the hole
Ahh, so sorry.
Old 05-16-2009, 11:01 PM   #5
Chevy1TonFun
Grease Monkey
Ahh, so sorry.
I just wanted to point that out, no big deal.
Old 05-17-2009, 07:09 AM   #6
mothertrucker424
the truck was dirt cheap and it needs 4x4 so i'll let yaa'll know
Old 05-17-2009, 07:18 AM   #7
mothertrucker424
best thing i found was a picture of a solid axle with coils
Old 05-17-2009, 09:47 AM   #8
drivethechevy
drivethechevy's Avatar
there has got to be some how-to's on the internet for this, a solid axle swap in is something that i have seen more and more of on the newer trucks, and my little brother is paying me to build his 02 chevy into a bad ass 4x4 and i am planing on doing this swap in it, his is already a 4x4 but the IFS on the newer trucks is proble prety close to the same weather its 2x or 4x
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 05-19-2009, 05:34 PM   #9
ghettoluxury
ghettoluxury's Avatar
if you plan on using a divorced transfer case then no prob just use front axle and springs from a 73-87. When you decide to do this use the front spring hangers from the very front of a 73-87 and the rear shackles and hangers from the very rear of a 73-87. Just flip the rear hangers around backwards and line them up on the inside if the frame.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
