Old 05-16-2009, 06:36 PM   #1
frankyjoet
Red face Dist gear/oil pump gear
Hi again, i would like to know what way do i turn the oil pump gear, clock or
or counter? This seems the only way to solve the timing prob. also does it matter if the #1 plug is at 530 or 630 o'clock on the dist. Thanks in advance.
frankyjoe
frankyjoet is offline   Reply With Quote
Old 05-16-2009, 09:57 PM   #2
special70gmc
special70gmc's Avatar
Re: Dist gear/oil pump gear
you can turn the oil drive shaft with a long flatbladed screwdriver
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 05-17-2009, 08:16 AM   #3
LONGHAIR
The simplest way to do this is to just stab the distributor where it needs to be. If it "hangs up" because it is missing the oil pump drive, just turn the engine slowly and it will "drop" into place (when it lines up) because the oil pump doesn't turn until it does. It works every time. You can turn it by hand or use a remote starter button.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
