12-30-2002, 04:06 AM | #1 |
pulled oil drain plug,drained 5 gallons of fuel!?!?
my truck has been sitting for a while (4 months) and I decided to get it running... well I checked the oil and it seemed awfully high and lean... I pulled the oil drain plug and out comes enough oil\gas to fill a 5 gallon bucket! What the hell is going on here? Cracked intake manifold? Carb? Neighborhood kids playing pranks? Any suggestions? Thanks 67 C-10 3/4 327/TH400
12-30-2002, 04:11 AM | #2 |
My other Love
Well i would have to say your motor was reeeaally flooded. your oil turned real bad or someone is trying to make a monkey out of you. Welcome to the board from not too far North of you! Are you sure its oil and gas or could it be water?
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-30-2002, 04:13 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
My bet it a bad fuel pump.If the diaphram gets a hole in it the truck may still run but at the same time it will dump fuel into the block(which ends up in your pan).DON'T run your eng. untill you change the oil.Let's hope your bearing damage is minimal.
You can check the fuel pump by applying vacume to the "in" side of the pump(where the fuel line from the tank is connected to the pump)If it won't hold vacume the diaphram has a hole in it. Good luck.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 12-30-2002 at 05:01 AM. |
12-30-2002, 04:17 AM | #4 |
My other Love
well with all that gas in there, I would be pretty sure the motor is clean inside
12-30-2002, 06:15 AM | #5 |
Fuel pump. Been there, done that.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
12-30-2002, 10:27 AM | #6 |
fuel
If float sticks in the down position while parked it will do this when fuel pressure is applied.Turning to start. Also could be fuel pump as others said.
12-30-2002, 11:06 AM | #7 |
More hobbies than money!
I'll vote for fuel pump! don't think you could get that much gas in the oil from the float sticking, though i could be wrong.
'70 cst10/swb 350, 3 on the tree, factory buckets. '70 GMC lwb 350/350 ps,pb '72 c-10 lwb 350/350 a/c, ps, pb '72 Blazer project |
12-30-2002, 01:52 PM | #8 |
electric fuel pump
I'm not real familiar with electric fuel pumps but have seen them where the pump still runs when key in on position and truck not running. Wouldn't this situation dump loads of fuel into motor with truck equiped with el. fuel pump and someone listening to radio?
Does anyone run an electric fuel pump and how does theirs work? Maybe a better option if used right avoiding diaphram hole situations. Not trying to change subject of this post maybe we should start another.
Bob |
12-30-2002, 02:08 PM | #9 |
Back in the sticks
No, the fuel pump only runs for 2 seconds without distributor input. On fuel injected models anyway. Didn't think about the not fuel injected ones. Dang. Sounds like a mechanical fuel pump problem though. I'd check the diaphragm. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
12-30-2002, 02:37 PM | #10 |
FUEL PUMP!!!!!!!!!!!!!!!!!
12-30-2002, 02:47 PM | #11 |
I would agree with the fuel pump. You can at least pull it off and inspect the diaphram and gasket!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
12-30-2002, 04:23 PM | #12 |
454 club
fuel pump
We had the same problem on the chevelle. fised the pump and changed the oil. it works just fine.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
12-30-2002, 08:16 PM | #13 |
My other Love
Oh i put a new 300 6 into my 1981 f150. the motor came out of a fuel injected truck but i put a carb back on it. There were no provisons for a mechanical fuel pump so I put and electric one on. If I don't start the truck right away it will flood like a s.o.b
12-30-2002, 09:57 PM | #14 |
hey hooter, if it floods that quick you either have too much pump pressure or the needle valve and seat is not holding in the carb. you only need about 7 to 12 psi for the carb, and you can install a fuel regulator inline to solve that problem. if the needle and seat are'nt holding you're sucking down way too much fuel.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
12-31-2002, 12:12 AM | #15 |
FUEL PUMP! been there done that 3 Times !
12-31-2002, 12:30 PM | #16 |
SKINNY TIRES RULE!
I have no idea what the problem is, but welcome to the board from Bothell.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-31-2002, 10:59 PM | #17 |
Semper Fidelis
that happened to my dad he trashed his engine unfortunately
72 Chevy C 20 with 402 For sale 85 GMC K2500 83 Trans Am Cedar City, Utah (Missouri Native) |
