Old 05-17-2009, 03:57 PM   #1
monolith
Zero Albedo
monolith's Avatar
How will an axle flip affect towing capacity?
I'm contemplating a leaf spring flip on my 66 GMC 3/4 t longbed and it looks like the entire weight of the rear plus anything I'd want to tow would be suspended from from the U bolts.
I'd be keeping the entire spring pack intact if I did this mod.
I'd likely only be pulling a tow dolly or flat towing- but would I need to run extra beefy U bolts and mounting hardware rather than a "standard" flip kit to keep some towing capacity?
Any advice would be greatly appreciated- thanks for your time and for all of the great tips that I've already picked up.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 05-17-2009, 09:30 PM   #2
XXL
Seņor Member
XXL's Avatar
Re: How will an axle flip affect towing capacity?
Other than the shear and tension of the bolt, nothing appreciable. Use a quality u-bolt, washers, and nut and you should be in pretty good shape. Tension strength of a grade 5 bolt is around 120,000 lbs psi, so you're not likely to break the bolt.
XXL is offline   Reply With Quote
Old 05-18-2009, 12:55 AM   #3
monolith
Zero Albedo
monolith's Avatar
Thank you so much for the response!
I didn't know what load those bolts are rated for and would hate to end up creating an unsafe situation on the truck that I'd have to reverse.
or worse- dropping the rear out of the truck while hauling something.
Baz
68 Dodge Charger
