05-17-2009, 07:01 PM | #1 |
Edelbrock 1406, throttle cable bracket?
I'm putting an Edelbrock 1406 carb on my 402, and I'm looking for suggestions on what to use for a throttle cable bracket. I have the Lokar chrome bracket, but it looks like it will interfere with the carb/adapter stud in that corner. Ideas?
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
05-17-2009, 09:44 PM | #2 |
Re: Edelbrock 1406, throttle cable bracket?
I have a similar carb, w the lokar cable, kickdown and bracket. Cannot remember the #'s, but the bracket uses the stud in the DS rear of the carb and has a set screw to keep it from moving. I'll go outside and get a pic if you like.
James
James |
05-17-2009, 10:47 PM | #3 |
That sounds like the kit I have. Stock intake or Edelbrock? I've got to use the spread to square bore adapter, which means both holes in the corner of the carb are used.
05-18-2009, 01:53 AM | #4 |
Mine is a edelbrock performer rmp. Not sure if the 2 holes being occupied will change anything. I had a few questions about the setup and lokar answered them well. Might be worth giving them a call.
James |
05-18-2009, 12:00 PM | #5 |
72 blue, I will be using a similar setup. Granted, it will be a long time before I get there, I'd like so see some pics of your setup whenever you have a chance to snap a few.
My apologies for stepping in on your thread cruiserman..
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
05-18-2009, 01:22 PM | #6 |
70+ ( Old Skool Club )
I can't help you with your question but wanted to tell you I have an Edelbrock 1406 on my 396 ( I bought the truck that way) and it works great. I've had the truck since 2001 and haven't had any carb problems .
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-18-2009, 02:19 PM | #7 |
I think I forgot how the adapter plate works. The stud to the intake will be flush on top, correct? That means the lokar throttle cable adapter should work OK.
05-18-2009, 02:23 PM | #8 |
72 chevys 4 life
I just have the throttle cable bracket that was original with the motor and it works fine. I have the edelbrock performer and 1406 edelbrock carb
I dont call it being young and dumb....I call it young and havin fun |
