Old 05-17-2009, 09:07 PM   #1
Aarons72
Aarons72's Avatar
A terrible weird noise...help
I know this is nearly impossible to figure out over a forum but I'm hoping someone has experienced something like I can describe.
For about two weeks every day I drive my truck I hear this nasty rattle/clicking/possible grinding sound...it only happens when I'm driving and it only happens when I'm accelerating... (not power braking, not coasting, not in park) It's the worst when I'm going about 30 or when I'm going steady up a hill. It's not really loud but my wife hears it, my uncle hears it and one of my friends that I took for a ride could hear it. I have spent about 12 hours under my truck and under my hood tinkering with stuff trying to eliminate the noise and it is driving me crazy. In the mean time I did fix some other problems I didn't know about though
Any tips would be very appreciated
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 05-17-2009, 09:15 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: A terrible weird noise...help
U-Joints?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-17-2009, 10:06 PM   #3
thebrown83
thebrown83's Avatar
My guess is spark knock or a cracked flexplate. google that and you might find the answer.
thebrown83 is offline   Reply With Quote
Old 05-17-2009, 10:23 PM   #4
KB71C10BBSUPER
KB71C10BBSUPER's Avatar
Sounds like a spark knock, probably does it more on hot days. Try some premium, fattening up the fuel mix. You can also retard the timing a couple degrees. Check your cintrifical advance in the dist. Last, with the motor running @ 1500 to 2200 rpms, dump 12oz of cool water down the venturi's of the carb slowly. Keep the motor reved (don't let it stall) up as you pour the water thru both barrels. This will help break up some carbon deposits in the combustion chambers.
KB71C10BBSUPER is offline   Reply With Quote
Old 05-17-2009, 10:24 PM   #5
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
I would check the u-joints they can make some bad noise sometimes. if thats not it then its probably your diff.
mikajo39 is offline   Reply With Quote
Old 05-17-2009, 11:25 PM   #6
long69
center carrier ? when mine went it was a very curious noise, like something slapping around down there somewhere. but it was easily spotted from under the truck. maybe speedo cable?
long69 is offline   Reply With Quote
Old 05-18-2009, 12:40 AM   #7
Aarons72
Aarons72's Avatar
thanks, these are all good things to look into. I will continue chasing the problem...
Aaron Anderson
*1962 Nova
Old 05-18-2009, 12:56 AM   #8
ashx2
Have you checked the carrier bearing? Mine was making some of the noises you mentioned some time ago.......it was the carrier bearing. Good time to change the u-joints while you're at it.
Greg
ashx2 is offline   Reply With Quote
