Old 05-17-2009, 09:35 PM   #1
68/k-30/462
4wd big block motor mounts
Im looking to find a set of 4 wheel drive big block motor mounts for my 68 , I have small block ones now , and have header clearance problems with the transmission crossmember . The collector runs right into it , the exhaust is bent up and over . I have been told factory bb ones set the engine up more . Does anyone know about this , or know how to fix this problem ?
68/k-30/462 is offline   Reply With Quote
Old 05-17-2009, 09:39 PM   #2
72blue
72blue's Avatar
Re: 4wd big block motor mounts
dont think there was a bbc in a 4wd.
James
72blue is offline   Reply With Quote
Old 05-17-2009, 09:52 PM   #3
drivethechevy
drivethechevy's Avatar
big blocks were never offered in 67-72 4x4s
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 05-17-2009, 11:13 PM   #4
Skirkpat
Skirkpat's Avatar
don't spend alot of time looking, they don't exist.
Skirkpat is offline   Reply With Quote
Old 05-18-2009, 12:33 AM   #5
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
My suggestion would be to ask some of the other guys in the 4x4 section of the forum. For me I ordered a DIY4x4 crossmember and have poly-bushings for my motor mounts. I know that there is a kit that bolts to the original crossmember that allows you to use poly-bushings and may raise the motor up an inch or two. I do some looking around for you.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-18-2009, 01:26 AM   #6
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
drivethechevy's got it. Just use the SBC mounts and things will bolt into place.
Might want to peruse this thread as well:
http://67-72chevytrucks.com/vboard/s...d.php?t=263273
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
