Old 05-18-2009, 12:04 AM   #1
Captainfab
60-66 Nut
OEM Rockers vs Aftermarket Rockers
I did a quick search and didn't find anything concerning my question.
Has anyone bought the actual OEM rocker panels for the '67-'72's and are they exactly like the ones originally on the trucks? I've got a set of rockers made by Key Parts and I'm really not happy with them. I know everyone says that all aftermarket parts need a little work, but these need quite a bit of work to get them to where I will be happy with the results. I'm just thinking I may be better off getting the OEM ones instead of re-working these aftermarket ones. Especially since it is a customers truck, I don't want to have to explain to him why I have "X" number of hours re-working the new rockers. I've already spent several hours re-working the other parts I've installed. Some guys just don't understand....
Old 05-18-2009, 05:45 AM   #2
Re: OEM Rockers vs Aftermarket Rockers
Most folks don`t understand what it takes to do someone else`s job.The problem is they need to start understanding.Does that customer want to wait for you to locate a pair of minimum $100 a piece N.O.S. rockers?i`m sure it would be less money vs your time,but locating them is time,not that it`s all charged time.What are the problems you`re having,overall?
Old 05-18-2009, 07:33 AM   #3
70cst
70cst's Avatar
In the Circuit Rider's resto...I had an option of NOS rockers or repops. I purchased repops from one of our Site Vendors and Curt (he is doing the resto) said these went in w/o any issues and the quality was top notch. That was my experience. I have bee told there are various makers of these rockers and the quality varies. There are good repops.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-18-2009, 07:53 AM   #4
Isn`t Key Parts Tri-Plus?The best repro.
Old 05-18-2009, 07:57 AM   #5
Curt's_72
Curt's_72's Avatar
My experience has been the aftermarket rockers are fine. I scored a set at a swap meet for cheap and they weren't even from the same manufacturer. The guy doing my bodywork had no issues installing them. His issue was reworking previous shoddy cab corner repair. I'd use OEM if these parts were easy to aquire and reasonable in cost, but in most cases they aren't.
Curt's_72 is offline   Reply With Quote
Old 05-18-2009, 09:20 AM   #6
70cst
70cst's Avatar
I think the rockers that I used came from Tri-Pro Automotive.
Old 05-18-2009, 10:25 AM   #7
leddzepp
Moderator
leddzepp's Avatar
You can still get NOS ones from gmpartsdirect.com, but they are pricey.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-18-2009, 10:54 AM   #8
Livrat
Member #1049
Livrat's Avatar
I have installed dozens of sets of both OEM rockers and the Tri-plus/key parts ones..
Even have used the very early other manufacturers repros.. (those are horrible).
Even the OEM ones do not always fit.. same of the Tri- plus ones.. but personally I will always use the new versions of the aftermarket ones over the OEM ones because to me they are "stupid expensive" (you can buy dozen Tri-plus ones for the price of a pair of OEM) plus the quality and fit is the same if not at times, better (the tri plus ones even weigh 1 lb more than OEM) .. but every truck is different.. an OEM part from one truck will not fit great on a different truck..
On a side note. Just in case you are interested I do have a set of NOS ones that have been sitting on my shelf for at least 20 years that I would sell.. $250 plus shipping
Livrat is offline   Reply With Quote
Old 05-18-2009, 11:39 AM   #9
Skirkpat
Skirkpat's Avatar
When I bought mine at Chevy duty about three years ago, I held both NOS and repop, compared the opposite side to the other back to back, and could find no noticible difference, I bought the repop. Classic still sels the NOS if interested, but they have gone up from the 80.00 that I thought was outrageous.
Skirkpat is offline   Reply With Quote
Old 05-18-2009, 07:15 PM   #10
mbgmike
We install them without many problems. Of course we may not know what a problem is anymore cause we just do it without thinking. I have not installed an OEM rocker that fit any better or worse than a TriPlus one. the rockers are usually one of the easiest part to install. There are some crappy rockers being sold however. Each truck is a little differant.
mbgmike is offline   Reply With Quote
Old 05-18-2009, 10:31 PM   #11
STP67-72
STP67-72's Avatar
I have used both. I have put dozens on through the years. I built a truck years ago that had one of each and nobody could tell me which was GM. Triplus parts fit the best. If they do not say that i want use them or sell them. I have GM rockers that i just keep saving for my keeper trucks one day. Good luck.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 05-18-2009, 11:43 PM   #12
Captainfab
60-66 Nut
Well for one I'm thinking I'll need to stretch them about 3/16" to make them the same length as the originals. Then the fitup at the A-pillar will require cutting and adding metal to fit the contour. The fitup at the B-pillar is not perfect but acceptable. And then I still have the passenger side to do. Who knows what that will fit like.
Maybe I'm expecting too much from aftermarket parts I don't know. I was just looking at a post in the 'Paint and Bodywork' section about another members rocker issue and his fit much better than mine. Aside from the fact that I've already spend a lot of time re-working the cab corner and floor pan, I'm just frustrated that better/ more consistent quality parts aren't available. Like I said, this isn't my truck it's for a customer and I'm trying to educate him on just what it takes to get his cab in good shape again.
Thanks for all the replies guys, I guess I'll just re-work what I have.
Old 05-19-2009, 05:29 AM   #13
Hey Captain,I know how frustrating it is.The parts are specific application.If it doesn`t fit that,what does it fit?...Right?
Did you just get these parts or have they been around?Who did you get them from.Was it Key Parts directly or a more local distributor?And,they had Key Parts stickers on them?Same questions with the corners.I know there were aweful corners made,bad batch or whatever.But,I don`t think those were Key Parts.The corners don`t wrap far enough(not enough radius).They needed sliced in the corner and welded.Nothing like a welded seem in a rust-prone area.Not to mention a good bit of bondo.It made me wonder if tiger hair and`glass wasn`t better.I wonder if your parts were the earlier junk and not the new and improved.That`s what I`m getting at with all the questions.I don`t doubt your problems with fit or ability to deal with it.Many of us have been there/done that.
Old 05-19-2009, 11:10 PM   #14
Captainfab
60-66 Nut
Did you just get these parts or have they been around?Who did you get them from.Was it Key Parts,directly or a more local distributor?And,they had key Parts stickers on them?Same questions with the corners.I know there were aweful corners made,bad batch or whatever.But,I don`t think those weren`t Key Parts.The corners don`t wrap far enough(not enough radius).They needed sliced in the corner and welded.Nothing like a welded seem in a rust-pron area.Not to mention a good bit of bondo.It made me wonder is tiger hair and`glass wasn`t better.I wonder if your parts were the earlier junk and not the new and improved.that`s what i`m getting at with all the questions.I don`t doubt your problems with fit or ability to deal with it.Many of us have been there/done that.
All of the parts for this cab were purchased from Classic parts a couple months ago. Every part has a sticker that says 'Key Parts' and it also has a Tri-Plus part number. So far about half of the parts have a decent fit, but the rest have been a PITA. Nothing I can't handle, just wasn't plannig on this much extra labor.
I went ahead and took a few pics today so you guys can see just what I'm talking about. Half of the fitment problem at the cab corner is the cab corner needs some more re-work. The gap that you see there is with the rocker and cab corner actually overlapping slightly down at the bottom edge.
Old 05-19-2009, 11:37 PM   #15
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
I got mine from Action Crash parts and mine looked exactly like that.
But for less than $20.00 each, what did I expect? with a little working and help, they were fine.
NOS stuff is fine when you can get it, but people who have it want usually way too much.
I mean did the stuff fit THAT great when they made it from Chevrolet???
My truck had so many shims in it that were factory when I took it apart I had to laugh. Most "factory" stuff is not what it's cracked up to be.
Example. Back in '07 I had a customer who had a mid-90's burb in my shop. It got hit in the rear and front and he insisted on OEM parts, ONLY! He would even pay the difference if the insurance company wouldn't. So I ordered factory OEM headlights at a tune of almost 200 each!
I got the lights and guess what? They were DEPOT lights with GM stickers pasted on them. The aftermarket lights (Depot) were $90.00 each from Action Crash. (Over half the price!) Go figure... BTW, the Depot lights fit perfectly and looked great.
I learned a very valuable lesson that day. Not all OEM stuff is what they say it is.
I never told my customer about the lights... but he would have been pissed. Besides if Chevrolet trusts them, why shouldn't we???
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 05-20-2009, 07:21 AM   #16
Richard,GM didn`t use the practice of substiting aftermarket with their parts stickers.N.O.S. means the same part your truck was made with on the line.These days,with GM licensing being sold,you see parts marked as gM made be vendors who never provided factory parts.It`s more about GM making more money than your assueance on quality of the part.With 67/72 N.O.S.,if there`s a bar code,it ain`t N.O.S.
N.O.S. is rare and costs way more for that reason as well as it`s being "the right stuff" and nothing compares.
I have a question about this repair job.Is the door mounted and used to fit?
Old 05-20-2009, 08:47 PM   #17
Richard8971
??? I wasn't referring to NOS parts with what I posted about the headlamps. I know what NOS means.... New Old Stock.
I just told the story to mention how GM even uses aftermarket parts to fulfill their needs when they feel it is necessary. Some aftermarket stuff is crap and some isn't. Personally if my truck was in an accident, I would not hesitate to use quality A/M parts from our site vendors in repairing my truck. But I do understand the importance of having found nice NOS parts.
Don
Sherlock Holmes
Old 05-20-2009, 09:03 PM   #18
Richard,we must be miscommunicating.I guess my point is your point about the current practices has no bearing on 67-72 parts.I never questioned your understanding of what n.o.s. is.By your point,in the future n.o.s. could as likely be aftermarket as oem.My point is that would not be the case with these parts.N.O.S. "is" what it`s cracked up to be when talking this old.
Old 05-20-2009, 09:14 PM   #19
Richard8971
You are correct. I am refering to new factory stuff, not NOS. Sorry for making it sound that way.
D
Sherlock Holmes
Old 05-20-2009, 09:37 PM   #20
OrangeCrush1970
OrangeCrush1970's Avatar
I just put a set of Goodmark rockers in. They fit very well w/ minimal work-
http://67-72chevytrucks.com/vboard/s...d.php?t=341198
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 05-21-2009, 10:56 PM   #21
Captainfab
60-66 Nut
Yes I have been using the door often to check the fitup of the various parts. I also have an un-molested '68 that I've been using to verify measurements since the PO had attempted repairing the '67 cab.
Those Goodmark rockers look like they fit like they should. I've heard that even though Goodmark parts are made in Taiwan as are the rest, their quality is better. Where did you purchase your rockers from?
Old 05-22-2009, 09:39 AM   #22
Skirkpat
Skirkpat's Avatar
I know that when Goodmark started (with Chevelle parts), they were using Genuine GM stamping dies, I also know that GM destroyed alot of thier dies after they were out of production. I do not know about 67-72 rockers, but that might be why they are as nice of a fit as they are?
Old 06-10-2009, 11:00 PM   #23
Captainfab
60-66 Nut
I had a member contact me asking what I did to get the rockers to fit, so I thought I'd post the pics here for all to see. In addition to the issues preciously mentioned, I discovered that the rocker wasn't out far enough where it meets the cab corner. After inspecting an original rocker I decided to make a cut horizontally about 6 inches long to allow the lower part to move outward to line up with the cab corner. You can see this in the pic as I haven't completed the weld yet.
Old 06-11-2009, 04:05 PM   #24
mclairmo
That gap is huge. Is it possible that the distance between the front and the back of the cab at the bottom has stretched? Maybe when the new floor pan was installed? I would mock up the door and make sure the gaps are all correct before moving forward.
mclairmo is offline   Reply With Quote
Old 06-12-2009, 12:37 AM   #25
Captainfab
60-66 Nut
No the distance from the A pillar to the B pillar is as cxlose as possible to the original factory measurement. And the door has been used all the time to check fitup and alignment. The gap at the rear of the door was crap to start with, and isn't much better on my '68 that hasn't been touched. Just the way some were from the factory.....these were just trucks in their eyes.
