Keepin it old school
6 lug rotors and drop spindles??
I was curious if the 6 lug disk brake rotors from CPP would work on any aftermarket drop spindle for our trucks 71 and later? CPP says their 6 lug rotors will fit their drop spindles or stock 1971-72 and 1973-87 stock spindles..
Well if they work on stock spindles they should work on my aftermarket drop spindles too right?? I have DJM 3" spindles that work with all the stock brake parts for 1 1/4 rotors. They just word it that way because they dont want you to buy someone elses spindle right? http://www.classicperform.com/Store/...ruck/CP4R5.htm Does anyone else carry these rotors?? I'd like to switch to 6 lug in the front.. Right now I have 5 lug rotors from a 85 |
Re: 6 lug rotors and drop spindles??
Wes & GMC Pauls both had 6-lug rotors as well as ECE. If the rotor will work on a stock 71-87 GM spindle, it will fit a drop spindle as well. The caveat is determining if the spindles are for 1.00" lt. duty brakes (avail from 81-87 IIRC) or the 1.25" HD brakes (71-87). Most of the 6-lug aftermarket rotors are of the 1.25" variety.
Member of the longbed union.
I would stay away from the CPP, I've heard a lot of bad things about them lately. I bought mine from performanceonline.com and they were cheaper then CPP. Mine came with 2 1/2 drop from McGaughy. I got the SD crossmember with the 73-87 arms on my 64. I got my whole brake kit 3 days after I ordered it.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#4 | |
Rods
![]() Join Date: Nov 2002
gm has 6 lug rotors but u would have to use the 88-93 drop spindle
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
does the ball joints bolt onto our Arms? and do you know the size of the spindle? I've been told that the 92 3/4 rotors bolt onto the 71-71 spindle!
60-66 Nut
![]() ![]() Join Date: Mar 2007
You have to switch to a '63-'87 C20 lower control arm
No, the '88-'09 light duty 3/4 ton rotors won't work on the '69-'87 spindle.....they're close but the caliper won't line up with the rotor. You have to use the '88-'98 1/2 ton or light duty 3/4 ton spindle.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-11-2009 at 12:41 AM. |
thanks for the info!
Rods
no u will use the 88-93 spindle. use the 69-87 3/4 ton lower arms and stock upper. use the 88-93 ball joints. you will have to use the 1.25 spindle and rotor combo to keep six lug
Hollister, CA.
![]() Join Date: Sep 2006
Do you have to stop at 93...or can you use an 88-98 spindle ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
88-98 is the same. From what I remember, the difference is single vs. ext. cab p/n's.
Rods
The only thing that changed was the abs sensors
#13 |
I wish I knew all thise before I bought my break kit.
#14 | |
60-66 Nut
There fixed it.....I hate not being able to edit posts.....and having un-cooperative fingers.
#15 |
Rods
Well you were right 88-09 will not work... Hehe
#16 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
#17 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#18 | |
#19 | |
![]() now you have like 5 minutes to edit then the option goes away....
![]() ![]() Last edited by joe231; 06-13-2009 at 11:40 PM. |
