Old 05-18-2009, 01:18 PM   #1
Keith Seymore
Keith Seymore's Avatar
How do I: Change out the Vent Window Assembly
Need to replace the driver's side vent window.
I did a search and found this thread, which seems to indicate I can remove/replace the vent window without removing the door glass. Am I reading this right?
http://67-72chevytrucks.com/vboard/s...vent+window%22
Also - it appears my truck has the two piece seals, which I am under the impression it should not have.
At any rate, any tips would be appreciated.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-18-2009, 06:50 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: How do I: Change out the Vent Window Assembly
you do not have to remove the large window you have to lower it though.. its easiest to replace the whole glass tho if the big window is in good shape and moves easily
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-26-2009, 11:23 AM   #3
Keith Seymore
Thanks, guys. Got 'er done this weekend.
It wasn't too bad: I was able to replace the vent window without pulling the door glass. The hardest part was getting one of the phillips screws loose!
I also replaced all the rubber on the driver's door. The LMC rubbers fit the vent window pretty well; it was a little tricky getting the rubber on the window track at the rear of the door and the attachments didn't quite line up with the slots in the door itself but not bad considering.
K
1979-1986
1986 - 2019
Old 05-26-2009, 03:38 PM   #4
JohnC
JohnC's Avatar
I need to do the same thing on mine. I was considering the one piece windows though. I never use the vent window anyway.
JohnC is offline   Reply With Quote
