05-18-2009, 03:14 PM | #1 |
Suspension Question
I searched and couldn't find this exact question, but I am not sure what to tell the search engine anyway.
I know you can use 71-72 spindles on a 65 and you can use 73-87 ball joints on a 71-72, SO....... is it possible to install the 73-87 ball joints AND spindles on a 65? I have noticed a couple of similar question brought up concerns about Camber adjustment. This could be fixed with a longer upper control arm. Global West does the same thing with some GM cars because the taller spindle and longer upper control arm actually give the truck a better camber curve than stock. Simply put, the longer control arm moves in a larger arc; the larger the arc, the less severe the "in and out" motion of the ball joint centerline. If know one makes longer upper control arms I might just fab some myself. This is not something I am doing anytime soon, maybe NEXT summer. Just running through possible options. BTW, no pics, but I changed the drivers side door pins on Saturday and layed on the wet pavement to pressure wash the entire bottom. What a mess, the truck before and me after. Tonight I remove the rigged column, pull the wiring harness and get it ready for the new harness I am putting in.
Don't let my username fool you, I have become brand blind. Cool is cool, period. 1965 C-10 - "Whipping Post" 1958 Biscayne - "Ruby" 1961 IH Scout 80 - "Gaucho" (My wife's new project) 1938 Chevy - unstarted project. |
05-18-2009, 03:19 PM | #2 |
Sunburst C10!!!
Re: Suspension Question
i dont see why it wouldn't work but why dont you just go to the junkyard pick up a 73-87 1/2 ton pickup and yank out the frontend
im sure you can find one there everywhere
Gage 1967 C10 Shortbed Stepside |
05-18-2009, 05:18 PM | #3 |
Member of the longbed union.
I would have to say the best way to do it is just 73-87 control arms and spindles. Are you just wanting to keep it 6 lug? If thats the case then why not go with a disc brake kit. I ordered mine from POL. cost me 630 including shipping!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
05-18-2009, 05:47 PM | #4 |
I was just trying to do the least amount of work for the least cost. That sounds stupid with my "fab a new upper control arm" statement, but if I had to Fab one, it would cost me little and I could really make it trick. For parts I have a donor 78.
5 Lug is preferred and I refuse to pay someone for a disc brake kit when I can fab and covert other items to do the same thing for less. Time I have, the money to do what I wish I could, I don't.
05-18-2009, 06:43 PM | #5 |
Resistance is Futile
The other answers are correct GM, but you are correct also. There are varying degrees on this swap.....cross member, a-arms, or as you mentioned just the spindles. I believe all the control arms have the same size opening for ball joints, just press in the correct balljoint and go. You will get into some brake line relocation/splitting etc. I'm guessing you figured as much.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-18-2009, 07:08 PM | #6 |
I'm not too sure about the camber problem from swaping other truck parts on our 64-66, but if you have the donor why not just swap all parts off the 78!
05-18-2009, 07:43 PM | #7 | |
Use the spindles, upper/lower a-arms, calipers, rotors, splash shields, tie-rods, & drag link. If your sticking w/manual steering use your original steering arms. If you're switching to power steering, use the pwr box & pitman arm from the donor & get one of the frame reinforcement plates from a board vendor (Captainfab sells some). You can swap the entire c.member too if desired (some feel it's easier). I've always just swapped the parts to the existing c.member. If you want to keep it 6-lug, several board vendors also sell the 1.25" HD 6-lug conversion rotors that swap right on.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-18-2009 at 07:46 PM. |
05-18-2009, 08:03 PM | #8 |
i just finished s simillar swap... i used a 85 donor truck and swaped the entire crossmember....
i used the manual steering box and stock 65 pitman arm. i used the 85 steering linkage (drag link etc.) i just orderd a booster mcyl from cpp the swap was very easy ... id do it again in a heartbeat... im not going to say its easier than just swapping over piece by piece.. but it looked easier to me to take it out as a unit... good luck! |
05-19-2009, 07:41 AM | #9 |
Registerd User
I got 84 ball joints and ect on mine. Just had to convert my c20 lower arms to c10 the the ball joints went right in.
