Old 05-18-2009, 03:38 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Burb seat issues
Just thinking,,,
I would guess that all burbs would have the holes in the rear to mount a 2nd, 3rd row seat.
I picked up a 2cnd row seat and only one of the rear brackets lined up to mount with the body. I have some extra seat feet and put them up to the rear of the seat frame while it was in the truck and not even close.
Front brackets matched up fine.
Anyone else have this issue?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-18-2009, 05:41 PM   #2
BobS
BobS's Avatar
Re: Burb seat issues
Smitty,
I've run into the same problem, the way the seats mounted must have changed somewhere between 67 and 72. My Suburban is a 72 and has the original front and 2nd seats in it along with two more seats from an earlier Burb. The earlier seat brackets are different and aren't spaced the same as the factory bolt holes for the 3rd seat. I'm not at home right now or I'd take some measurements for you.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 05-18-2009, 05:44 PM   #3
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 71meangreenc10 View Post
Just thinking,,,
Smitty
Got any pictures?
Hart_Rod is offline   Reply With Quote
Old 05-18-2009, 10:15 PM   #4
71meangreenc10
Here are the pics,
1st one shows the brackets being way off in the middle, now the seat is in the far left rear hole and the front brackets mount up.
2. This pic shows the far right bracket that I changed with a spair, and the bolt hole is still off by over 1/4 inch.
Suggestions?
Need a seat that will work......
Smitty
71 C30 Wrecker
Old 05-18-2009, 10:21 PM   #5
Hart_Rod
Hart_Rod's Avatar
Did your truck orginally come with a full bench as the second seat?
Old 05-19-2009, 12:40 AM   #6
71meangreenc10
The code is A80, Second and Rear Seat.
Dont know if it is a full seat.
Smitty
71 C30 Wrecker
Old 05-20-2009, 05:04 PM   #7
71meangreenc10
TTT,
Need some help........
Smitty
71 C30 Wrecker
Old 05-20-2009, 08:52 PM   #8
CG
BlahBlahBlah
If your burb didnt have the third bench the second seat is wider...no need to slide past it to get to the third seat.
Any way you can show a picture with a wider view...hard for me to get the perspective on this one.
Old 05-21-2009, 01:18 AM   #9
gmbpmidway
having same issues....
gmbpmidway is offline   Reply With Quote
Old 05-24-2009, 10:51 PM   #10
capev86
i like the full second row seat option. my dad's 72 burb had the full 2 rows and my "new" 72 burb is equipped the same. my dad installed a back seat from a same era blazer as a third row seat. my plans call for an 80's third row seat upholstered to match the factory interior. i will find a way to install the floor brackets for the newer seat. that way it is a simple flip and unplug job to pull the seat for extra cargo space. will worry about a 60/40 middle bench in the distant future.
capev86 is offline   Reply With Quote
Old 06-05-2009, 05:25 PM   #11
71meangreenc10
Wont be able to take pics for a while,,the burbs at the outlaws house now.....Moving is a beast....
Still looking for help....
Smitty
71 C30 Wrecker
Old 08-17-2009, 07:52 AM   #12
jku72
I just went through a PITA 3rd seat install on my burb. What I found while crawling under the truck was that the brace that the seats bolt into, as well as the seat belts, appears to be drilled for several seat brack positions, but only the holes in use had the nut welded to them, and of course the wood was only drilled in the needed locations. After measuring up, and figuring out which holes were the right ones for the seat i was installing, I drilled from the bottom up and got the correct holes. I then had to tack weld my own nuts to the holes, being careful not to set the truck on fire (also right near the fuel tank!).
I figure i'll have to fabricate the seat front hold down brackets, as original ones are scarce as hen's teeth, and no ones else makes them.
Whats interesting is that I installed a wide second seat in a truck that originally had a narrow second seat, and now i have 4 seat belted positions in the second row. To get to the third seat, which only kids want to sit in, you have to jump over the seat, but no one seems to mind. In fact, the teens prefer it, as it is far away from the adults, and sit in the way back even if the second seat is empty.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
