View Poll Results: What motor should I go with?
305 remanufactured with 3 year warranty (no core charge) 7 29.17%
350 remanufactured with 3 year warranty ($500 core charge) 14 58.33%
Used 350. 3 12.50%
Voters: 24. You may not vote on this poll
Old 05-18-2009, 06:29 PM   #1
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Help!!! I need your opinions.
OK, here is the deal. I am getting ready to shell out a bunch of money for a motor.
As some of you know, I have an '83 305, most likely out of a Camaro in my truck now. I have an EFI distributor, headers and an Edlebrock 1406 carb. Outside of the fact that it leaks oil like the Exxon Valdez and blows smoke really bad when you start it up, it starts quickly and is a very strong motor, plenty of power and has never given me a days worth of trouble.
Most people are trying to get me to get a 350. Only trouble is, most people that have a nice 350, keep a nice 350. I can get a 350 reman with a 3 year warranty, but I have to pay about $500 for the core charge.
Now the question is, sense I have to transfer my stuff anyway, do I get a reman 305 ($1200.00, no core charge, 3 year warranty), or get a 350 ($1200.00, $500 core charge, 3 year warranty). I know my 305 stuff will work with a 305, but as allot of you guys have said in the past, MOST of the things should transfer over to a 350, but I am still taking a chance.
I can also get a used (been sitting for 4 or so years), recently rebuilt 350 with lots of goodies for $1000.00. (From a friend) But he never got it running right and says it's the timing. To me that's a big 'what if..'. No warranty and I could be buying someone else's troubles.
I know the 350 should be a more efficient motor. I also know the 350 has more HP than a 305 but how do they compare MPG wise? Oh, and one more thing. I need to have my 700R4 rebuilt. So that cuts into my budget some. The money I would have to pay for a core can get my tranny done...
Oh, one more thing. I want to do this locally. I am not interested in getting anything online. My local economy needs my help and I plan on keeping my money here, even if it does cost me a little more. Also the local help if I have any issues with warranty stuff is a plus.
Honestly, I don't care if it's a 305 or not. People won't know it's not a 305 when they look under the hood, so what do I do? Keep to the facts... comments like "305's suck, 350's rock dude!" won't help me decide. I need to know why... please.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 05-18-2009, 06:45 PM   #2
fine69
fine69's Avatar
Re: Help!!! I need your opinions.
I think you should fix your oil leaks.
Put new valve stem seals in and save a bunch of money.
Thats where the smoke on startup is coming from.
$75 bucks or so for a engine gasket kit.
$22 bucks for cone type oil seals. And on a SB chevy you can use the factory and the aftermarket ones BOTH at the same time.
When you have the engine out also put in a new timing chain and gears.
$50
You just saved lots of money.
If you are not capable of doing all this, find someone local who is.
Get rid of the "friend" who wants $1000 for a used 305 that he couldn't get running right.
If you were in Ohio i would sell you a good 305 crate engine for $300
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 05-18-2009, 06:52 PM   #3
Richard8971
$50
I wouldn't have a problem with this but...
Until I open my motor, I have no idea what shape the cylinder walls are in, valves, crankshaft, bearings, rings... etc. I have to assume the worst in that it will need a complete rebuild. Once I tear into my truck, I have limited time to get this done. So for a master kit (with pistons) is about $400-500 bucks here in town. Add the machining work, that could take you close to $800-$1000.00. And then it still doesn't have a warranty. No point in rebuilding the heads without putting new rings in... you will just blow them out!
The motor came from a junk yard so I really have no idea of it's history or anything. If I take the time to open my motor, I will rebuild it correctly. No reason to cheese it at this point. The hard part is taking it out!!!
I am capable of doing the work, short of machining.
Don
Sherlock Holmes
Old 05-18-2009, 06:55 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
I agree with fine69. Fix what you've got. Maybe even take it in for a rebuild if you think it needs it. You know you have a good motor that just might be a little on the aged side. Stick with it and don't let good ol' Murphy throw his book of laws at you! Good luck!
69GMCLonghorn is offline   Reply With Quote
Old 05-18-2009, 07:04 PM   #5
Richard8971
So what you are saying is that $1000.00 spent on rebuilding what I have is better than a remanufactured 305 w/ 3 year warranty for $1200.00?
Yeah I could do a gasket kit, but once you get the heads off for a valve job, you might as well replace the oil pump... and then just a couple of bolts more removed and you can re-ring it...
I honestly have no reservations on rebuilding what I have, I am just wondering if doing the work myself to save a couple of hundred bucks is worth it.
Hmmm....
Don
Sherlock Holmes
Old 05-18-2009, 07:12 PM   #6
fine69
fine69's Avatar
Hmmm....
Don
Don, you dont have to take the heads off to put valve seals in.
Just take the valves springs off. Which can be done with the motor in. But much easier with it out.
If it runs strong then you don't need to re-ring it.
If it ain't knockin' why put new main and rod bearings in???
I don't think you understand what i mean.
Neither of us is talking about rebuilding.
Doesn't sound like you need more than a couple hunderd bucks and some time to be in ship shape.
If it runs good, strong, why replace it? Fix the problems you have.
Board member #6
Old 05-18-2009, 07:24 PM   #7
Richard8971
I don't think you understand what i mean... If it runs good, strong, why replace it? Fix the problems you have.
I understand what you mean.
My front main is the leaky spot. My rear main leaks too, but not as badly as the front. There is no way in h*** I am going to change those with the motor in the truck. I have to pull my transmission for a rebuild at the same time so taking the motor out at this point is just a couple of more bolts and an hours worth of work. Then I will have easy access to everything. To change the front main I will have to take the oil pan off and the timing chain cover.
Well, once I have those off, why wouldn't I want to replace the timing chain and oil pump? I mean I am already there. There is no reason to take the time to take the valves out and not get the heads reworked. Once I have the heads off for a valve job, why not re-ring it, put new bearings in and get the motor honed?
I am not looking for a quick fix. Honestly, the cheapest thing for me to do at this point is do nothing and let it leak until something bigger breaks. To me this is going to be alot of work either way. My way, I fix it where it should hold for several more years.
Don
Sherlock Holmes
Old 05-18-2009, 08:17 PM   #8
bac1755
bac1755's Avatar
Why wont they let you use the old 305 as the core for the 350? I dont know if its the place you went or what but the place I went to had no problem with it.
1971 GMC
1972 Small Blocked DATSUN 240Z Dads old car
bac1755 is offline   Reply With Quote
Old 05-18-2009, 08:23 PM   #9
Richard8971
Hmmm... never thought of that... I could always ask. But if I remember correctly, they didn't want my 305 as an exchange. I mean they didn't even want it as an exchange for another 305!
D
Sherlock Holmes
Old 05-18-2009, 08:41 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Since it's a good runner right now, I'd buy a FelPro KS2600 gasket set to reaseal the complete engine for 45 dollars, a set of valve seals, a timimg chain set, and fix what you have. You have about 100 dollars in it including some engine paint.
If it runs and doesn't knock and carries good oil pressure, why fool with what isn't broke ? You need some oil leaks repaired and some valve stem seals. Don't throw the baby out with the bath water.
Old 05-18-2009, 08:44 PM   #11
Richard8971
If I DO take this route, I would at least get a valve job on both heads (that way I can replace the head gaskets), and replace the front and rear main seals. I would also replace the oil pump, water pump and timing chain. I figure this route could end up costing me about 350-500 bucks.
As long as the lower end was strong, it should be OK for a little while longer. I dunno...
D
Sherlock Holmes
Old 05-18-2009, 08:47 PM   #12
Richard8971
Engine paint?
I am not sure of the oil pressure. I would replace the pump either way I go. Just good insurance.
D
Sherlock Holmes
Old 05-18-2009, 08:50 PM   #13
bac1755
bac1755's Avatar
D
If its rebuildable I dont see why they wont take it. Maybe they want something else with it, ask them if they will take a 13" black and white T.V?
1971 GMC
Old 05-18-2009, 08:53 PM   #14
Richard8971
Don, If it runs good, strong, why replace it? Fix the problems you have.
Darn you. Now you got me thinking again.
These were my thoughts in the first place. But friends close to me keep pressuring me to get a new 350.
I just want my truck to run without leaking! (WAAAHHHH)
D
Sherlock Holmes
Old 05-18-2009, 08:54 PM   #15
Richard8971
Sherlock Holmes
Old 05-18-2009, 08:58 PM   #16
Tx Firefighter
D
You're letting your friends spend your money. Fixing your leaks is 45 dollars worth of gasket set. Who cares if it is a 305 or 350. They look exactly the same from the outside.
Old 05-18-2009, 08:59 PM   #17
bac1755
bac1755's Avatar
D
If its not to bad just fix the leaks. Then rat nest some money so if it does ever go you can put a bad @$$ 350 in it.
1971 GMC
Old 05-18-2009, 09:39 PM   #18
Richard8971
The issue is not if I care if it's a 305 or 350. I just want it to run good either way.
The "pros" on the 350 is that, if I am going to rebuild my motor, then go for the 350. It has almost 100 more HP than a 305 stock for the same amount of money. I can see where my friends are comming from. But if I just fix the leaks, then this is no longer an issue.
If I wasn't on a budget I would replace my motor with a 350 hands down. But I also have my transmission to fix as well. I just need to choose which is more important.
That's a tough one to debate...
Don
Sherlock Holmes
Old 05-18-2009, 10:31 PM   #19
knsmodels
I make Models
knsmodels's Avatar
why do you keep making excuses to spend more money....not to be mean....you said except for the oil leaks you are happy with it right now....why not take the cheapest way out and see how long it lasts??? there are guy running sbc engines with 100k, 200k, 300k....without changing anything.....its not making any noises just leaking fix the leaks and drive it until it breaks....why does it need an oil pump, timing chain or anything if it is running fine....not stepping on any toes just saying what I would do....
ps .....get the tranny fixed that is more important than some leaky oil
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 05-18-2009, 11:10 PM   #20
Bears63
...just another truck junkie..
Bears63's Avatar
First, fix your tranny and see what you have left in the budget after that. The engine is still running so do the tranny.
Now, I have been in a situation like this before. I had a leaky 350 with a bunch of miles. I pulled the motor and freshened up the gaskets and seals and slapped it back in. A month later a rod started knocking and I ended up buying a reman 350 with 3 year warranty. What I'm saying is this, if you have the money to get a reman engine then go for it. If you are short on your budget after fixing your tranny, then just fix the leaks and see how long it lasts. My situation was a bit of a fluke, but it's always a possibility as well. Trust me, that warranty is piece of mind too.
As for 305 vs 350, either one is fine. They are both good engines and I wouldn't hesitate to snag a 305. But, if the place will take your old 305 for core, then get the 350. In the end it is your hard earned money to part with. It's not an easy choice, but go in the direction that you think is best for you.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-18-2009, 11:34 PM   #21
berencam
berencam's Avatar
I find the quality of a personally rebuilt engine to be better than a remaned one. However if you want to get a remaned one, why not search craigslist for a old junker 350 block? should be able to get it for 50-100 bucks and theres your core. Drop the crate in, then take your time and rebuild the 305 you have and keep it as a backup. Or just fix the problems you have now, The front man seal can be changed with the engine installed still, and i have seen people change the rear main with the engine installed too. It is possible. If it where mine this is what id do....1. pull engine and trans, place engine on stand and send transmission off to be rebuilt(400-500 bucks at the most?) 2. take the block down to a short block( no oil pan, no heads, no timing cover.) 3. send the heads off. (300-400 bucks very most). 4. replace all gaskets, oil pan, mains, timing cover and such(should run 150-200 for all the gaskets and stuff.) Should end up with a good transmission, and a good engine, if you want change the cam while your in there and give yourself a bit more power. But it shouldnt cost more than 1k to repair the tranny and overhaul the engine.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 05-18-2009, 11:37 PM   #22
berencam
berencam's Avatar
btw read the fine print on that warrenty, it states the warrenty is only valid when you install it to replace the current engine in your vehicle with the same engine. My 350 crate specifically stated it must be installed into a 89 and above 1/2 to be valid, and i must provide proof of engine maintenance.
Old 05-18-2009, 11:45 PM   #23
jbristo67
resident oilfield trash
jbristo67's Avatar
Don
Where are you getting these new motors from. Reason I ask is because most places you can pass of your 305 as a 350 core
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-18-2009, 11:52 PM   #24
jbristo67
jbristo67's Avatar
Wow your blue again
2011 Nissan Armada
Old 05-19-2009, 12:01 AM   #25
sleepertruck72
sleepertruck72's Avatar
I say fix watcha got, and have your tranny rebuilt, or ask your "friends" to pay for your crate engine. It will give you more pride and joy to know that you fixed it, versus the pride and joy of your friends spending your money. Heck if you let me, I'll spend your money and get you a big block 427 crate Good luck with your decision.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
