Old 05-18-2009, 06:34 PM   #1
chadvicki
Can some help please?
I am having trouble with my truck idling smoothly. While in drive I am at 600rpms. It will idle smooth then I feel like a bump or hiccup and the rpms drop one tick or 100rpms. This happens quickly and every 5 to 10 seconds. If I put into neutral the rpms go up and the idle is rough. Here is what I have done so far:
1. Replace ignition wires
2. wire looms to keep wires off headers
3. replaced cap and rotor
4. replaced all vacuum lines
5. new fuel filter
After the cap and rotor it was really good for a day. Now its back to the same old thing.
Any help would be great.
Thanks,
Chad
Any ideas what I could do next? Carb rebuild or swap?
chadvicki is offline   Reply With Quote
Old 05-18-2009, 06:51 PM   #2
cardreams
Re: Can some help please?
is it a 305 or 350 I would pull the value covers off and check to make sure all rockers are going up and down might be the cam
cardreams is offline   Reply With Quote
Old 05-18-2009, 06:59 PM   #3
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
If you raise the rpm to like 2000 or so does it still have a hiccup every now and then? have you checked your points if your still using a points style setup?your carb may also be gummed up or dirty
mikajo39 is offline   Reply With Quote
