Old 05-18-2009, 07:47 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
power to cab, but nothing when i turn the key to start the truck
okay, i have power to the stuff in the cab, heater blows, turn signals headlites all work....but when i go to start it with a battery hooked up, AND jumper cables hooked to a nother truck.....nothing happens....
NOW, nothing on the alterator is hooked up, no wires going anywhere, just the belt is hooked up.
if i wire the alt. up will the engine start up like it should? or is something completely wrong..
reason im doing all of this is ive been looking at buying a swb truck with cracked block...was pricing motors today after schoool...and thought to myself,,,HEY why dont i see if i cant get my 350 in my parts truck to run...so i slapped my old quadrajet on....wired everything back together, scooted all the junk over so i can set down on the seat, turned the key...and (start reading at the top now lol)
John
1999 Toyota Tacoma 4x4
Old 05-18-2009, 08:35 PM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: power to cab, but nothing when i turn the key to start the truck
this has happened to me you are going to need to replace the electronics(dont remember the actual name) behind the key. or just use a screwdriver to the starter after the key is on.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-18-2009, 08:37 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is it in park?
Old 05-18-2009, 08:38 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
^ yea that helps too
Old 05-18-2009, 09:11 PM   #5
oldblue1968chevy
it should be, the first time i tried it in gear (im used to 3 spd on the coumn lol) and it made a wierd noise, just barely, and then nothing...then i put in in park and tried again, nothing...
i gotta truck whiz comming over tomorow to help, my dad loaned him 6 sheets of printer paper and he tried to give him 5 bucks lol, so instead he offered to help me out tomorow after school lol
John
Old 05-18-2009, 10:06 PM   #6
cdowns
cdowns's Avatar
try jumping the wire at the neutral safty switch// near the floor on steering column it's the 2 heavy gauge purple wires just disconnect from switch and run a jumper wire between them MAKE SURE your in park and try the ign switch to see if it will start
Old 05-18-2009, 11:44 PM   #7
red71c10
The Red Menace
red71c10's Avatar
Dead starter??? I've had that happen. Turn the key and get nothing because the starter is totally dead.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 05-18-2009, 11:54 PM   #8
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
could be a dead starter mine was toasted to a crisp but if you hit it with a hammer it would twirl a bit if you do end up pulling the starter off make sure uve got some leverage and a place to put it cause that mother is heavy!
mikajo39 is offline   Reply With Quote
