05-18-2009, 09:20 PM | #1 |
1967 K20 front disc conversion?
I think I found a parts truck(s). will 1987 3/4 tone chevy and Gmc trucks work for conversion parts? and if I am right what should I look for? and i will be able to use power booster and master cyl too right?
1967 K20 Stepside Longbed 250-6 sm420 |
05-18-2009, 11:11 PM | #2 |
Post Whore
Re: 1967 K20 front disk conversion?
It will swap right in, you'll need to do some changes to your front brake lines though, the fittings won't be the same for where you hard lines thread into the newer rubber lines and when you change out to that newer master, your lines again won't be the right size.
I swapped in a 78 3/4 ton's Dana 44 and master and ended up just running new hard lines.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-19-2009, 06:08 AM | #3 |
Re: 1967 K20 front disc conversion?
You`re wanting the complete axle,correct?it sure can be done,as Yukon Jack said.
05-19-2009, 04:54 PM | #4 |
I was planning on using the whole axle, actually both front and rear so the gear ratios are the same. Plus the master cyl and booster.
Might even grab the 350v8 and seat, rear bumper, etc.
