Old 05-19-2009, 09:34 AM   #1
72-c20
Packrat
72-c20's Avatar
Dana 44 spindle interchange?
Getting new wheel bearings, etc... put into my '72 K20 and the spindles need replaced.... I can't find any 72 3/4T spindles. will the 73-76 3/4T spindles work? if so, what all has to change to use them, as they are different?
thanks,
mick
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 05-19-2009, 12:01 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Dana 44 spindle interchange?
I don't have any details to share but I do know there are two types/sizes for spindles used on a D44. They are both swapable, you just need the matching WBearings with whatever spindle you end up with. Pre-72 is the smaller one if I remember correctly. Late model 72 and up is what your after..they have the 297 ujoint on the axels, instead of the smaller 260.
Hope this helps
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-19-2009, 12:13 PM   #3
72-c20
Packrat
72-c20's Avatar
my shafts have the smaller 260 u-joints.
Old 05-19-2009, 01:12 PM   #4
Burt4x4
Burt4x4's Avatar
Sounds like you need a donor D44 with the 297 shafts, then you can simply swap in the shafts and spindles on out..might be cheeper than buy new spindles? Getting away from thoes 260s is a good idea if you wheel moderate to hard trails.
Old 05-19-2009, 09:03 PM   #5
jerry moss
Born Psycho
jerry moss's Avatar
use the spindles, axle shafts and whichever hub assembly that matches the spindles. if the spindles are from a big hub 44, your 72 hubs will work. i swaped both my 72s over to 73-76 style for ease of parts availability and larger axle shafts & u-joints.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-31-2009, 09:00 AM   #6
72-c20
Packrat
72-c20's Avatar
thanks for all the info. was able to use a set of 73+ NOS spindles BlueJeep had on hand, and upgraded to the 73+ axle shafts and spicer U-joints.
it's back on the road!
