Old 12-30-2002, 06:20 PM   #1
gmtruck71
xwrench2003
Question K-10 drivetrain ?
My 71 K-10 has 3.07:1 gears. The rear has failed and I would like to replace with something higher such as 3.42 or 3.55. The rear is 12 bolt GM the front is Dana 44. Cannot find 3.54 or 3.55 for the rear, and cannot find 3.42 for the front. I can only find 3.73s or the 3.07s for both front and rear. Has anyone done this, and is there any later models that will fit under the chasis without any modifications. Does anyone have 3.73s front and rear complete housings with rear posi? Thanks for your time.
Marty Hall
1971 K-10 LWB Cheyenne (461\T-400)
93 S-10 Blazer (330,000 and still going)
86 SS Monte Carlo (40,000 miles)
85 Chevy Scottsdale
02 Jeep Liberty
gmtruck71 is offline   Reply With Quote
Old 01-01-2003, 08:45 PM   #2
gmtruck71
xwrench2003
ttt
Marty Hall
85 Chevy Scottsdale
02 Jeep Liberty
Old 01-01-2003, 08:48 PM   #3
Mudder
Mudder's Avatar
The 3.73's would be good gears for you and are a lot more common.
Mudder is offline   Reply With Quote
Old 01-02-2003, 12:37 AM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I'd much rather have the 3.73's than the 3.07's......my truck has 3.07's and I hate them. Why anyone would order a 4x4 with 3.07's is beyond me. I've been trying to tear them up for 4 years now and still haven't got a really good excuse to replace them yet other than the fact that I hate them.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-02-2003, 02:18 AM   #5
too many
too many's Avatar
gmtruck71,
What height tire are you running? I currently have a "set" of 3:07s in my 4x4, but have a set of 3:73s with rear posi on the shelf for future use. (lucky find from a 71 Blazer) I am running a 31" tall tire and am also planning to put a 700 O.drive in it in the future.
You may want to check out the RPM range/tire dia before investing in any gears. ...probably not a lot of diff between 3.73s and 3.55s. GOOD LUCK!!
"My wife says I cant have them all - I tell her I can try!"
too many is offline   Reply With Quote
Old 01-02-2003, 12:49 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm running 35" tires with 4.10s. My first Blazer had 35" tires with 3.73. It was ok, gas mileage was much better, but it had a little less off the line. If your running 35s or less, go with at least the 3.73s.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-02-2003, 10:41 PM   #7
The Joker
GMCTruck
I took some 3:54 out of a blazer once and put them in my 1/2 ton 4X4 once and did not like them. The 3:54's took more gas but I sure had a big top end crusin down the high way. So I went back to the 3:73. which is good for normal use.
The Joker
The Joker is offline   Reply With Quote
