Old 05-19-2009, 11:52 AM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Gas tank Questions 86-87?
Does anyone know what the difference is between 86 gas tanks and 87?
87 was the first year they put electric pumps in the tanks but I thought the tanks were the same. My parts guy is telling me they are different numbers. Also is there a difference between left and right?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-19-2009, 12:06 PM   #2
79 silverado
Re: Gas tank Questions 86-87?
plastic baffles inside to keep fuel from sloshing around on grades/through curves because of the in-tank fuel pumps...
oh, also I believe that the tanks are different from one side to the other based on where the filler neck attaches. Its not right in the middle of the tank and its more towards one end than the other so you cant just flip one around for use on the other side...
Last edited by 79 silverado; 05-19-2009 at 12:08 PM. Reason: forgot other half of the question...
79 silverado is offline   Reply With Quote
Old 05-19-2009, 12:13 PM   #3
ont_guy_38
ont_guy_38's Avatar
Yes there is extra channeling in the bottom of the 87 tank for the fuel pump but other then everything else is the same.I put a 87 tank in my 85 because i needed one and my parts truck was a 87 .It will accept the older sending unit ok but your gas guage will never read below 1/4 tank because the float hits the metal inside the tank.I found that out the hard way as me and my then 2 year old daughter had to walk home cuz it ran out of gas and still said 1/4 tank.....lol...there is no difference between left and right i dont think
typed too slow...lol...silverdao beat me...but i dont belive there is a difference from side to side
ont_guy_38 is offline   Reply With Quote
Old 05-19-2009, 12:20 PM   #4
ont_guy_38
ont_guy_38's Avatar
Looked on LMC it says right there left and right are the same
Old 05-19-2009, 08:48 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Darn... found a new tank but its for an 86
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 05-19-2009, 11:08 PM   #6
thinair
thinair
thinair's Avatar
I was pretty sure that the top of the sender and the actual hole in the tank on the 87s was smaller than 86 down....................
The senders have a tab that sticks up and out and it fits into a slot/cutout on the tank.That designates LH or RH.So for instance,if you have a single tank truck,drivers side LH,and you just happened to buy a RH tank from someone that had dual tanks,your sender would sit in the tank backwards and your hoses and lines would point towards the outside of the truck instead of inward like they should.
thinair is offline   Reply With Quote
