Old 05-19-2009, 04:22 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Vintage Air Cowl block off help
I just put in a Vintage Air Ac system. The kit has you block off the passenger side vent and supplies a plastic plate to do so. On top of that because I installed a custom unit in order to shave the fire wall I had to cut through the cowl system to run my lines and bulkhead. I cut through where the old blower motor goes. So even though I have the vent covered over I have a hole about the same size of the vent cut open that air blows through with no way to plug it off with out some how shutting down that side of my cowl system. Has anyone done this or have any idea of the best way of going about blocking air to the passenger side of my fresh air system? I will see if I have some pictures to show you what I mean. I will try to take some better ones that show the actual hole tonight after work..
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 05-22-2009, 11:40 AM   #2
lts70
1970 Daily Driver
lts70's Avatar
Re: Vintage Air Cowl block off help
Anyone have any ideas?
Old 05-22-2009, 12:59 PM   #3
fastom
That's right, it's Copper!!
fastom's Avatar
That's the best reason for a shaved cowl.
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 05-28-2009, 02:41 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
I do have an extra cowl. How much would you guys say it would cost to have an auto body shop shave the louvers? I know it will be different from place to place, just looking for a rough magnitude. If any one has had it done what has it cost you?
Old 06-01-2009, 01:46 PM   #5
lts70
1970 Daily Driver
lts70's Avatar
Anyone have a guess on what it would cost to shave the cowl?
Old 06-01-2009, 03:23 PM   #6
fastom
fastom's Avatar
I had estimates anywhere from $700 to $1000. Best to try this yourself!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Old 06-01-2009, 08:32 PM   #7
tires2burn
tires2burn's Avatar
The fan sucks the air straight down from the cowl. I think you have to route your hoses through thr heater block off plate.
tires2burn is offline   Reply With Quote
Old 10-08-2009, 04:17 PM   #8
es67chevy
es67chevy's Avatar
You ever get this figured out? If so, what did you end up doing?
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 10-08-2009, 04:52 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
All factory A/C trucks have a flap that shut off the air going to the passinger side vent. That way the air can be recirculated to cool down more. You can either install one of those flaps or weld a blockoff plate in its place. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-08-2009, 10:41 PM   #10
Dynomutt
Dynomutt's Avatar
Here are a couple of pictures of that fresh air intake flap.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 10-09-2009, 08:49 AM   #11
tinkerdad
I’ve see a smoothed fiberglass cowl for our trucks on this site. Try a search.
tinkerdad is offline   Reply With Quote
