Old 05-19-2009, 08:24 PM   #1
66farmer
66farmer's Avatar
Need help on BIG BLOCK install
Can anyone link me to a big block install thread or tell me there problems that they experienced. I will be installing a 454 w/th400 out of a 1978 truck into my 1966 chevy step side.
Thank you so much for your help
66farmer is offline   Reply With Quote
Old 05-19-2009, 09:02 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Need help on BIG BLOCK install
Check with ChevyFleetside on here...he's got some good info...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-19-2009, 10:11 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
The engine will not clear the firewall, at least mine didn't. I cut the firewall and made kniches so the engine would sit back. You don't have to do this. You can move your motor mount perches to the forward holes. If you want to use headers they will not clear the left perch and you will have to put in later model ones or aftermarket ones. I used aftermarket. You can see some pictures of stuff here. http://67-72chevytrucks.com/vboard/s...d.php?t=259536 .. The thread seems to be shut down probably because of inactivity, but you can still read through it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-20-2009, 01:43 AM   #4
502tripower
502tripower's Avatar
Use the 73' up perches and headers or exhaust manifolds. There is no reason to cut the fire wall but, you may have to massage it a bit with a rubber mallet. I used http://www.stans-headers.com/gm_headers.htm 73-87 2" Chev Pickup.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 05-20-2009, 07:50 AM   #5
jason65
Registerd User
jason65's Avatar
Looks like you almost needed a shoehorn to get that big daddy in there.
jason65 is offline   Reply With Quote
Old 05-20-2009, 10:40 AM   #6
Chevy Fleetside
I decieded myself that I wanted the engine back as far as I could get it. That is why I cut the firewall. You don't have to do that. You can set it forward and all will be fine. Looks like my engine sits back about 2" more. Not a big deal. Just did it for looks.
Old 05-21-2009, 12:18 AM   #7
Captainfab
60-66 Nut
When I built my Suburban I used the '73 and up motor mounts with custom built frame brackets, moved it ahead aprox 2" to clear my taller valve covers and used '73-'87 pickup headers. I prefer the '73 and up motor mounts, but you could use the '67-72 small block mount brackets, or the '69-'71 big block brackets. Those will move the engine ahead a little if you don't mind those style of motor mounts. You would want to use headers for the same era that the motor mounts are from.
Old 05-21-2009, 12:27 AM   #8
Captainfab
60-66 Nut
For a trans crossmember you can use one from a '69-'87 pickup or Suburban.
Old 05-21-2009, 07:47 AM   #9
ApeKing
Trailers are for BOATS!
ApeKing's Avatar
Im planning a big blockswap myself so thanks for all the greta info!
The Rod Barons
C.C.
CSA
ApeKing is offline   Reply With Quote
