Old 05-19-2009, 08:50 PM   #1
speedfoxracing
bags or lowering springs ?????
i have a 69 c10 long bed and i,m thinkin bout doing bags. i just dont know weather i should do bags or should i just get the lowering coil springs. either way for the front i have to get the drop spindles to convert to disc brake. and i want the truck 2 sit pretty low. wut do u all think i should do or wut do u all like the best ??? plz any info helps
speedfoxracing is offline   Reply With Quote
Old 05-19-2009, 08:55 PM   #2
69RAT
Re: bags or lowering springs ?????
If you run full length headers with 2-1/2" drop spindles you'll have 5" of clearance to the collector with 28" tires. Much lower and you'll have problems! (experience)
'69 Chevy CST#'s 396/TH400, A/C
69RAT is offline   Reply With Quote
Old 05-19-2009, 09:00 PM   #3
speedfoxracing
yea well if i do coils i want 4 1/2 in the front and 5 in the rear. but with bags i can change it when i go 2 show and when i drive lower it up. which one do u think ride better ?
Old 05-19-2009, 09:11 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
BAG IT!!!!!!!!!
I just did mine and cup the lower A arms with drop in the spindles and it will lay out so the X memebr is 1.5" from the ground I also went for the C notch check out this thread
http://67-72chevytrucks.com/vboard/s...7&goto=newpost
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-19-2009, 09:14 PM   #5
speedfoxracing
did u do the c notch in the rear then ? like which one did u use
Old 05-19-2009, 09:23 PM   #6
big_al_71
big_al_71's Avatar
I want to bag mine just don't feel like doing it my self
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-19-2009, 09:44 PM   #7
70k52wd
Blaze-Air
70k52wd's Avatar
Either way you go, it's a lot of stuff involved. If you bag it you can always go back to coils.
70k52wd is offline   Reply With Quote
Old 05-19-2009, 09:50 PM   #8
Shane
Shane's Avatar
If you static drop with springs and spindles you will wish you had bagged it within a few months.
Shane is offline   Reply With Quote
Old 05-19-2009, 09:55 PM   #9
70k52wd
Blaze-Air
70k52wd's Avatar
well said.
Old 05-20-2009, 12:09 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
From the standpoint of useability/tuneability... bags cant be beat. Ive had both and Ill never use springs again.
Tom Vogel is offline   Reply With Quote
Old 05-20-2009, 05:49 AM   #11
Hottrucks
Hottrucks's Avatar
I used a piece of 4" pipe cut in half and a flat plate to box the frame in my C notch I also cupped the LCA's which is what gave it a great stance
Old 05-20-2009, 10:25 AM   #12
caja_larga
I have bags in the rear only. And think it is the best. Rides nice and I can haul stuff. My Dad has springs in the rear and can have much of a load.
Go bags at least in the rear.
caja_larga is offline   Reply With Quote
Old 05-20-2009, 10:28 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Mine is static 2.5/4.0. If I could do it over, I'd make the front 3.5 and the rear 5.0. If money ever becomes as common as grandkids, I'd go with bags on the rear, with the 3.5 on the front. As it is, I can haul a load if I need to....I just don't want to.
Member Nr. 2770
Old 05-20-2009, 10:43 AM   #14
cdowns
cdowns's Avatar
i've seen more than a few baggers on the pavement with line and or bag failure not one like that with springs// if the bags fail the tow truck guys just drag it up on the rollback on the rocker panels there aint much left when they're done
Old 05-20-2009, 11:05 AM   #15
The breaking point depends on use.I won`t notch a frame.I`d go to 6" with springs and must be careful with bottoming,very little hauling with that.%,ok with not so much load.4",you`re fine.Many peoiple are just fine with thioer springs and are happy about the money saved.I`m switching to bags,eventually because my truck will haul and tow.That is the only reasons for bags for my uses.It`s definately a thing to consider that bags add a ptential for break down.Just like air shocks back in the day.I`d never rely on them like most did to clear L60s.i`d get the springs right and use air shocks to load the suspension or air down for ride.You blow,you can`t go.Springs you put in and forget about them.
Old 05-20-2009, 03:55 PM   #16
speedfoxracing
yea wut do u all think bout this kit? it comes with the bags its not a 4 link cause i,ve called the ppl. all it does is replaces the coils with bags. but for a good price wut do u all think?
http://cgi.ebay.com/ebaymotors/ws/eB...3582&viewitem=
Old 05-20-2009, 04:43 PM   #17
Shane
Shane's Avatar
And if you put functional bumpstops under it along WITH the bags you can still drive it if you lose pressure.
Never seen one stranded that used bump stops.
Old 05-20-2009, 05:44 PM   #18
my67chevytruck
Under Construction
my67chevytruck's Avatar
Lots of good points, All comes down to personal preference.. good luck with your decision....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-20-2009, 08:53 PM   #19
speedfoxracing
but wut do u all think bout that kit on ebay ?
Old 05-20-2009, 08:58 PM   #20
Linky no worky.
Old 05-20-2009, 11:40 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
.....I won`t notch a frame....
Why?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-21-2009, 12:29 AM   #22
jbristo67
resident oilfield trash
jbristo67's Avatar
Why do you say that
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-21-2009, 02:30 PM   #23
speedfoxracing
yea sry heres a link that will work http://cgi.ebay.com/ebaymotors/Air-R...3A1|240%3A1318
or item number 260412374568
let me know wut u all think plz
Old 05-21-2009, 03:34 PM   #24
Shane
Shane's Avatar
Originally Posted by jbristo67 View Post
Why do you say that
Experience.
Old 05-21-2009, 04:31 PM   #25
70k52wd
Blaze-Air
70k52wd's Avatar
It's an Airbagit.com kit...I have no personal experience with them. I can't knock what I don't know. I have seen some mixed reviews on this forum. I would investigate more. Or, go with the flow. Airride kits, ECE parts, Suicidedoors kits. Look at what the majority does. That's my approach. JMO
