Old 12-30-2002, 07:27 PM   #1
GMC 3
what comp. ratio?
I am rebuilding a 350 + .060 and am reusing the pistons- they are in perfect condition- they are the stock style dish with 4 relief valves. what comp ratio will they give me with 64cc vortec heads. was thnking maybe about 8.5-9.0 but wasn't sure
thank you
GMC 3 is offline   Reply With Quote
Old 12-30-2002, 09:22 PM   #2
MikeB
MikeB's Avatar
Depends on the size of the dish and head gasket compressed thickness. Your deck height also comes into play. Assuming an 18cc dish , .038" gasket, and stock deck height (not milled), a .060 over 350 should be about 8.7:1 with 64cc heads. There's a CR calculator at http://www.rosspistons.com/CR%20Calculator.htm
Detroit Gasket makes a 028" composition gasket that will bump it to 8.9:1. I wouldn't use thinner steel shim gaskets unless your deck and head surfaces are perfectly flat.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
