Old 05-20-2009, 01:04 AM   #1
BIG_J
BIG_J's Avatar
Questions about my 1979 2wd blazer.
I have a 1979 2wd k-5 blazer that i want to lower an make into a hot rod. I am wondering what company makes drop spindles and if i would need to get new shocks and if so what kind. I am planning on doing 4 inch lowering on the front and 2 on the back and putting 18-19" chrome wheels with low profile tires on them, would the 4 inch lowering be to much for them?.Also i was wondering if a door off of any full size 79 Chevy truck would fit on my blazer, thanks,John.
BIG_J is offline   Reply With Quote
Old 05-20-2009, 01:38 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Questions about my 1979 2wd blazer.
for the drop components summit racing has good prices for the front drop spindles and springs and the back drop shackles or you could remove the over load spring the 79 door will be a direct fit for the doors that fit 73-87 truck, 76-91 blazer, and 73-91, and crew cab, but to be a direct fit and correct I would use a 77-80 door, and for 73-76 door it's not made for power door locks or windows and has a smaller door panel and shaft for the window crank is shorter, and 81-87 door will work just the door handles and door panels are different
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-20-2009, 01:41 AM   #3
flamingbig10
6.0 powered square
oh and welcome to the site
Aaron
Old 05-20-2009, 01:46 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Welcome to the site. It's nice to see 4X2 Blazers on the road. Wish I had one.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-20-2009, 08:16 AM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Welcome to the site, when you get time go over in the blazer side of the board and you will find a lot of info for your blazer. I ablazer has a 1" block under the springs so you can pull that out and then one one long leaf spring. YOu can also put 2" shackels on but it will rub your gas filler a little bit. The front if the easy one, what flamingbig10 said will work just fine and the same about the doors too.
tvblazer78 is offline   Reply With Quote
Old 05-20-2009, 11:09 AM   #6
silvereagle07
silvereagle07's Avatar
Welcome aboard!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 05-20-2009, 11:30 PM   #7
BIG_J
BIG_J's Avatar
thanks for all the advice hopefully can do some work on it when i get my next paycheck!
Old 08-05-2009, 11:25 PM   #8
BIG_J
BIG_J's Avatar
today i bought new fenders,doors, and hood from certi fit so going to be putting those on. so far i have 3 inch lower springs on the front and havnt done anything to the back, this weekend im putting my 5 inch flip kit on and then ordering some 2-3 inch drop spindles for the front, then it should sit nice, do you think i will have to cut out the inner wheel well? and will there be an issue with the tire hitting the fender when turning?
Old 08-05-2009, 11:38 PM   #9
flamingbig10
6.0 powered square
i have a 6" drop on the front of my truck and i don't have any fender rubing only on bumps and dips and I'm running 215/70-15 with a 7" wheel and 4.25 bs
Aaron
Old 08-05-2009, 11:49 PM   #10
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I run 245/60/15s with about 6" of drop up front. No rubbing other than in dips or bumps.
You will need new shorter shocks, or shock mount re-locaters.
Oh, and why the certi-fit parts? You should have been able to get some solid OE parts from trucks that were getting parted out for the same or less $. And then you have a quality part that will fit without much work. Certi-fit parts are often times a pain in the you know what. I have gotten them in and had to trim back 1/8-1/4", or add just as much, or re drill mount holes that were not even close. At least an OE part would line up for the most part. Sorry, not trying to burn you just curious.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 08-06-2009, 12:59 AM   #11
BIG_J
BIG_J's Avatar
so far got the fenders on and they went perfect, the doors will be hard im sure becuase i have to put the window and lock stuff together.
Old 08-06-2009, 08:30 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would test fit the doors first. If they look good , then take them off and install all the goodies while laying flat on saw horses.
Much easier to work on that way, but will require a friend to help install once done.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-06-2009, 04:55 PM   #13
cochino12
It followed me home?
cochino12's Avatar
Just an fyi, you are probably going to get more drop than 5" from your flip kit, not sure why though. I had to get a 2" shackle to pick the rear up a little when I did mine, I think I ended up with ~8" drop from a 6" flip kit.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-06-2009, 04:56 PM   #14
cochino12
cochino12's Avatar
Just an fyi, you are probably going to get more drop than 5" from your flip kit, not sure why though. I had to get a 2" shackle to pick the rear up a little when I did mine, I think I ended up with ~8" drop from a 6" flip kit. I've only had that problem with my blazer, never had that issue with a truck.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
