05-20-2009, 01:47 AM | #1 |
what could be wrong?
I had to take my tranny out of my truck and doing so I turned the converter counterclockwise to take bolts off. I did this again when putting them back on. Was that the wrong way? I drove truck and shifted fine but then died on me and didnt want to start again. Whats wrong now?
Im thinking i knocked it out of timing turning it ccw. Is that possible?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 Last edited by yellowGT; 05-20-2009 at 01:49 AM. |
05-20-2009, 02:04 AM | #2 |
Cheyenne Super
Re: what could be wrong?
No it wouldn't have changed the timing by doing that.
Need more info. Does it crank or nothing at all? |
05-20-2009, 02:25 AM | #3 |
it turns... in fact it turned till i killed the battery. I will have to mess with it after work.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
05-20-2009, 12:24 PM | #4 |
What year truck and what kind of igniton? Carb or fuel injection?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-20-2009, 04:50 PM | #5 |
Wire off the neutral safety @ the starter would be my first guess. Second would be wires from the starter to the ign coil.
05-20-2009, 05:07 PM | #6 |
are all the wires still pluged in to the trans?
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost |
05-20-2009, 07:10 PM | #7 |
Kid's Mechanic
Now don't ask how i know this but is there a chance that you wiring harness or a single wire was pinched between the tranny and the motor ?? look behind the distributor and see if a wire wound up stuck
05-21-2009, 08:17 PM | #8 |
Weekend Warrior
I know about that too
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
