Old 05-20-2009, 08:36 PM   #1
lumpyguy
lowering cheap
I am building a budget 1969 gmc long box with 6 cyl I bought a cheap set of 2/4 lowering springs and its ok I would like to go lower without spending alot is it possible to cut the lowering springs a bit to tuck it a bit lower this will not be a daily driver just a fun weekend truck or nice day truck any ideas would be great thanks
lumpyguy is offline   Reply With Quote
Old 05-20-2009, 08:39 PM   #2
OARNGESI
OARNGESI's Avatar
Re: lowering cheap
Fronts yes rears no but you may wana cut the stock springs first to try you can also get blocks
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-20-2009, 08:51 PM   #3
cdowns
cdowns's Avatar
Re: lowering cheap
do you plan on centering the rear with an adjustable panhard or just run it lopsided how about the shock angle for a better ride quality or is the buckboard ride ok with you?
Old 05-21-2009, 06:27 PM   #4
lumpyguy
Re: lowering cheap
sorry I did get the adj panhard bar and shock relocator I think I might try blocks and cut the front springs a bit any other ideas thanks
Old 05-21-2009, 08:23 PM   #5
cdowns
cdowns's Avatar
Re: lowering cheap
if you're putting blocks on . you'll have the axel off the trailing arms ,it's a perfect time to replace those bushings . not alot of money alto abit more work but you'll be over half way there already
Old 05-21-2009, 09:43 PM   #6
ZombieWeinerDog
ZombieWeinerDog's Avatar
Re: lowering cheap
just got some spring clamps from ebay. they clamp the spring down and make it a little lower. i havent installed them yet, but they look pretty good
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-21-2009, 11:54 PM   #7
greygoose
greygoose's Avatar
Re: lowering cheap
would the clamps make the ride bumpy?
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 05-22-2009, 12:01 AM   #8
ZombieWeinerDog
Re: lowering cheap
well it says it improves the handling, which means the springs will be more stiff. i dont know if it will make it more bumpy
1972 longbed- 454
1967 shortbed- 355
Old 05-22-2009, 12:08 AM   #9
Ackattack
Ackattack's Avatar
Re: lowering cheap
I know it's not the cheapest way, but for the front I'd get some drop spindles. And while you're at it, go ahead and replace the ball joints and other components if needed. It will make it work good all together.
Ackattack is offline   Reply With Quote
