Old 05-20-2009, 10:43 PM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
Trick to putting in a new cross member??
I am putting in a new cross member for a auto tranny. Is there a trick other then tearing it apart to put in?/
thanks
vance
VanceH is offline   Reply With Quote
Old 05-20-2009, 10:45 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Trick to putting in a new cross member??
IIRC there is a spot in the frame about a foot back from the normal mounting location that has some reliefs built into the frame that let you slide the crossmember up into the frame.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-21-2009, 10:08 AM   #3
Alex Hayley
I am in exactly the same situation. With a stock transmission cross member, you can stick it in at a sharp angle and then twist it until the bolt holes line up.
Right now I am trying to put an aftermarket transmission cross member in. I am noticing that only one bolt hole will line up at a time.
Alex Hayley is offline   Reply With Quote
Old 05-21-2009, 10:10 AM   #4
Ackattack
Ackattack's Avatar
I always have put them in at an angle and used a hammer to straighten it out and move it into the right position.
Ackattack is offline   Reply With Quote
Old 05-21-2009, 10:39 AM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
This is how i have always done it as well, I either use a rawhide hammer or a deadblow hammer and a 1x4.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
