Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Trans tunnel Q's
I have a 72 Cheyenne Super I am currently building. It is an original small block turbo350 truck. I am going back with a 454 and a 700r4. Will I have clearance issues with the low hump trans tunnel because of the big block swap or is the clearance issue when you use a BBC with a turbo400? Hence the reason all BBC trucks I have seen come factory with the high hump trans tunnel. Thanks in advance for all the help fellas.
--Josh
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
its all about the +6 inches
Re: Trans tunnel Q's
if you have good cab bushings, you'll be ok.
They'll all be new.
