Old 05-21-2009, 09:46 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Stuck spindle removal
I have a front axle form a 72 K5 that I am dis-assembling for spare parts (axle was junk). Anyway, I have the hubs and rotors off, the splash guard off. I can't get the spindle to come loose. My book says to smack it with a plastic hammer, but I think it's just too tight or rusted in to pop out.
Any ideas on how to get the spindle out of the knuckle without ruining anything?
Once the spindle is off, the axle is supposed to pull through the knuckle, right? I've never pulled one of these apart before. I'm kind of practicing with this one before I do the u-joints and ball joints on my jimmy.
hgs_notes is offline   Reply With Quote
Old 05-21-2009, 10:13 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Stuck spindle removal
Wack the crap out of that spindle. Thats the only way its coming off. Then yes the axle pull out right through the knuckle.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-21-2009, 10:19 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
whk teh rap out of it!
and remember! keep your feet out of the way!...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 05-21-2009, 11:14 PM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
OMG did that suck. I just mutilated a 4x4 with a sledge hammer and used some chisels once there was a gap. One down, one to go. I'll have to wait until tommorow though cause that makes a LOT of noise.
Thanks for the tips.
Old 05-22-2009, 01:06 AM   #5
dammitmitchell
the pollock
dude... tap tapp tapp ya aint gotta beat beat beat hehehhee....
patience and love
AND PB blaster..
Army vet 02-08
Old 05-22-2009, 06:13 AM   #6
Alternate rotating taps.I use a solid nylon block and a heavy hammer.I also have a cold chisel I`ve ground sharp (and often need to regrind) to drive between the spindle and knuckle to get it started.soaking a good penetrant on it can help,like PB Blaster.
I never cuss when I get a tough one...never.
Old 05-22-2009, 07:18 AM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
Nylon Block!!! Where do you get one of those?
They also have a tool that screws onto the spindle. It looks like a big socket. Then you either screw a slide hammer onto the socket, or use a bolt and screw it into the stub axle end. I use the slide hammer method.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-22-2009, 08:22 AM   #8
hgs_notes
GEARHEAD
hgs_notes's Avatar
They make a tool for it? Of course they would. I can't imagine having to do this on the trail.
Old 05-22-2009, 08:33 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
If your spindle has been off recently, its alot easier to remove and it comes off with a couple taps of the hammer. So then you dont need the tool. I always grease up the tight fit for the next time i take it apart.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 05-22-2009, 08:47 AM   #10
LONGHAIR
The slide-hammer tool is really the way to go with this. I use to work on 4x4s for a living (all models) and that thing saved a countless amount of time and effort. THIS is the one I have. It's a ltlle expensive, but if it keeps you from destroying a spindle with a hammer, or mashing a finger....
It really comes in handy for a 4x4 owner.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-22-2009, 03:23 PM   #11
I wondred if there was such a thing for front drive axles.I`ve known about slide hammer tools for rears,like Ford-type.
Randy,The power company used to mount the feed conduit to houses using them as spacers off the wall.They were always mounted "in my way" and by the time I got there it was backfilled...couldn`t move.So,I`d unscrew the clamp and toss the block in the tool bins.I used to hand them out to everybody.That was years ago and i`m hopin`mine lasts.It`s a great helper...about 3/4" x 2 1/4" x 5".It`s held up to alot of abuse.
