Old 05-22-2009, 11:46 AM   #1
one66c20
Question 66 c20 rear cab mounts?
Anyone know of replacement rear cab mounts or how to fab up new mounts for a 66 c20? I've tried a thread search and come up not found. I have some ideas on fab'ing some just want other ideas. Anyone done it?
one66c20 is offline   Reply With Quote
Old 05-23-2009, 12:26 AM   #2
Captainfab
60-66 Nut
Re: 66 c20 rear cab mounts?
I'm not aware of any replacement rear cab mounts for the C20's and bigger trucks. The easiest would be to find the frame brackets from a C10 and just bolt them onto your frame, and then just use C10 rear cab mounts. You could also just fab some up if you have the ability to do so. They're really pretty simple.
Old 05-26-2009, 09:10 AM   #3
one66c20
Thanks Captainfab
The c10 mounts is a good idea. I was just gona fab up a set and use c10 bushings. Just thought there might be soom out there I have not come across.
Old 05-26-2009, 03:47 PM   #4
slorio
slorio's Avatar
If it is the rubber part that you need to replace for the C20, this outfit revulcanizes your original mounts:
http://steelerubber.com/
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 05-26-2009, 04:37 PM   #5
one66c20
Regards,
Steve
New Orleans
WOW Thanks Steve That is the exact mount I have.
117.00 clams and three week turn around. looks like the way to go.
Thanks for the info Steve
Randy
Old 09-06-2011, 04:08 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Ouch!
http://www.americanclassic.com/Googl...CMR63-1966.htm
66 C20 Service Truck:
