05-22-2009, 03:04 PM | #1 |
It's alsways something.....
I have a fat tire!
I guess its kinda of a combo that I have to adjust- There was no way to tell w/o getting the truck together, but the front tires rub, so I need opinions as to which way to go.
The tires are 255/70 and the rim is 9" wide (I had them widened) The truck has 2 1/2" Drop spindles and 1 coil removed from the front spring. (rear has neg 5" springs) Looks like the alternatives would be to change to a 7" wide rallye and narrower tire or to buy a lower profile tire and keep the 9" rims. I think a 255/50 would be a few inches shorter than the 255/70, but would be unfortunate to buy and put them on and still rub. Or I could put a stock pair of springs back on the front and raise it up a bit. Or would the 7" combo be better? |
05-22-2009, 03:12 PM | #2 |
Re: I have a fat tire!
i think a 235x70 with 7"rim 4"backspace would do fine
05-22-2009, 03:16 PM | #3 |
you swapped to 5 lug right? it look s like what happened is that the conversion stuck your rims out about an inch on each side. Im running the same wheel/tire set up you are (15x8) and Mine barely clear if I lower my front end if I were to lower that much, but I havent converted to 5 lug disc yet. The other guy will chime in too if im wrong
oh and we need more pics! nice truck!
1967custom Last edited by michael bustamante; 05-22-2009 at 03:16 PM. |
05-22-2009, 03:29 PM | #4 |
Might try the springs first, sounds like the cheapest solution to me, looks like that might give it just enuff room.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
05-22-2009, 03:34 PM | #5 |
IMHO i think the 7" wheels with a smaller tire would look best. right now it looks south of the border
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
05-22-2009, 06:54 PM | #6 |
i went from a 275/60/15 to a 245/60/15 and took care of that problem, this was on 15x8 wheels...
huge difference....
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
05-30-2009, 08:01 PM | #7 |
Changed tires out today and heres pics, went to 235/60R15 on fronts
05-30-2009, 08:11 PM | #8 |
much better Love that color blue...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-30-2009, 09:15 PM | #9 |
a 235 tire on a 9 inch wheel ? you better take turns carefully ,dont want to blow a bead
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
05-30-2009, 09:51 PM | #10 |
blood type; Retumbo
when my truck was that low I had 255/70-15's on 7" wheels. it filled the well nicely and didn't rub.
05-30-2009, 09:54 PM | #11 |
"a 235 tire on a 9 inch wheel ? you better take turns carefully ,dont want to blow a bead"
Goodrich specs 235 to 8.5" wheel, so I am not sweating the 1/2" extra |
05-31-2009, 12:43 AM | #12 |
Did the new tires take care of the rubbing?
Joe |
05-31-2009, 06:37 AM | #13 |
ENGINE BUILDER
I have 235 70 15 tires on 7 inch rims. It looks like you need more backspacing to pull the tires back inside the wheelwells.
JIM ZAG |
05-31-2009, 06:47 AM | #14 |
there is a member north of me a ways that had a whole case of them. but that was a couple weeks ago so who knows now, ....
just tryin funny. life is good.kent
eat,work,spend,sleep,repeat. |
05-31-2009, 06:56 AM | #15 |
blood type; Retumbo
actually 9 blocks north and 12 blocks east to be exact Kent.
05-31-2009, 09:10 AM | #16 |
Be carefully when you turn with the 235 tire on a 9 inch wheel
05-31-2009, 12:14 PM | #17 |
I am a Referee of life.
http://www.dakota-truck.net/TIRECALC/
http://www.miata.net/garage/tirecalcold.html This may help determine if tires will work out your problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
