BBC swap
I have a 454 that I'm going to swap into my '89 stepside. What engine mounts will I need (part # if anyone knows it) and will there be any hood clearance issues with the stock hood and a standard height dual plane intake/carb? Any other input is also appreciated. I used the search function and didn't come up with much. Thanks.
Old Skool Club
![]() Join Date: Jun 2001
Re: BBC swap
I'd think that the same mounts that were used on a 454 SS pickup would be what you would need. That info should be available through any parts vendors (O'Reilly's, etc.).
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Registered Chevy Owner
Re: BBC swap
To my knowledge the bbc and sbc use the same enging mounts. But I'm not 100% on that.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 1951 Chevy 2 ton flat bed Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 2008 Chevy Silverado short box 4x4 |
Re: BBC swap
im doing a 454 swap into a 95 so its the same thing. what trans are you using?
Re: BBC swap
I have a th400, but the I might use a t56 instead. I really would prefer the overdrive. The truck is currently a 350 5 spd.
Re: BBC swap
mine is a 350 with a th350 tranny and i have a built th400 to go behind the 454 so it should be a pretty easy swap. i just need a speed sensor that will work. i heard of taking the tail shaft off a 700r to the th350 and it will work but i dont really know
| Bookmarks |
