Biggest tires that would fit well without rubbing?
Going to replace the tires on the 76 3/4ton soon, figured I might as well go a bit taller than last time. Just wondering what the tallest tire anyone had experience running without getting any rubbing in the turns was?
6.0 powered square
Re: Biggest tires that would fit well without rubbing?
is it a 2x4 or 4x4
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
2x4, originally 454 now 4bolt 350, 14ff rear, camper special pkg with 9leaf springs...
I run a 33x12.5x17, with a 2" lift spring and balljoint spacer. I have no problems with rubbing when turning and di not have to trim my fenders.
-vehicle:1977 c20 camper special, 3/4 ton, 2wd, with a 350 |
Dually Pride
i run 235/85/16 (about 32 inches tall) on my truck, no lift, and could fit bigger, but its a 2wd one ton
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
i just put some 33x10.50 on 16.5x10 wheels on my 3/4 ton and they rub in the front of the fender so don't get 33x10.50s unless your gonna raise the front or trim your fender.
Rottenwood Garage Member
235-85-16
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 05-24-2009 at 06:54 AM. |
Right turn Clyde
I have 285/75/16s on the rear of my C20.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
BAD BOW-Silverado XST
Checkout this fit table.
http://www.coloradok5.com/tirefitmenttable.shtml |
#10 | |
I've run 255/85-16 BFG's with no problem on stock rims. They are listed at 33.3". I would not put 10" rims on the truck, been there, done that. I have run 33/12.50's for more than 30 years on 8" rims with no lift or fender mods and no problems on many 1/2ton 4wd and 3/4ton 2 and 4wd GM square body trucks. I know some that have run a 34" Interco tire with good results. |
