Old 05-23-2009, 06:02 AM   #1
John Pasinski
John Pasinski's Avatar
4 speed transmission
Hi; I'm looking at a '71 Sierra Grande. It now has a 454 w/ a 400 trans. This is all original equip. Well; I have a 4 speed manual trans & acces. from a '73 GM. Will this go in w/o too much customizing? Will I need to change trans mount, & drive shaft? Thanks all.
John Pasinski is offline   Reply With Quote
Old 05-23-2009, 08:00 AM   #2
LONGHAIR
Re: 4 speed transmission
You need to be more specific about which transmission you actually have. There are lots of them and the answers will vary depending upon which exact one you have.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-23-2009, 12:20 PM   #3
John Pasinski
I'll see if I can photgraph it and post them.
Old 05-23-2009, 12:36 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you can plan on a cross member, drive shaft, possibly cutting a huge hole and replacing the hump on the cab floor, maybe a speedo cable... couple odds and ends
Old 05-23-2009, 02:36 PM   #5
John Pasinski
Thanks......I'm looking at a cover now. I thought I would need that. I'm going to look at (buy?) the truck tomorrow, I'll know more then I hope.
Old 05-23-2009, 02:53 PM   #6
Longhorn Man
I guess a pedal assembly, Z bar linkages.... that stuff won't be easy to find since most BB trucks were automatics.
Old 05-23-2009, 05:38 PM   #7
John Pasinski
Uhhhhh..........What're Z-Bar linkages? Boy, you'd never know I'm an industrial mechanic huh?
Old 05-23-2009, 11:29 PM   #8
Longhorn Man
someone will post pics I hope.... it is the linkage/pivot point between the clutch pedal assembly, and the arm on the tranny that operates the clutch.
Old 05-24-2009, 04:38 AM   #9
John Pasinski
Ohhhh....Now I know what it is! The Truck garage uses units like that for their truck clutches. They're called a BELL CRANK. I think I can get all those accessories through LMC or NAPA. Piece by piece I think I'll be able to get this job done. Thanks guys.
