05-24-2009, 09:06 AM | #1 |
Problem with hub caps
Here is a pic of the truck with the full hup caps. The wheels are 15X8 ralley wheels, the ones that use beauty rings and center caps.The problem is the hubcaps move on the wheels. When I first put them on the valve stem is in the center of the notch for them. After a drive the valve stem is off to one side of the notch and pushed over to the point the valve stems are geting cut by the hub cap. What can be done to keep the hub caps from spining on the wheels?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
05-24-2009, 09:09 AM | #2 |
Re: Problem with hub caps
I dont know what the back of the hubcap or better yet the edge looks like but I would think there is have to be a way which you can bent the tabs to makt it tighter..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-24-2009, 10:05 AM | #3 |
I have the same setup on my 71 and do not have that problem. You will need to tighten the tabs on the back of the caps - bend them to fit tighter.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
05-24-2009, 11:33 AM | #4 |
Watch out for your cornhole !
I've taken the old MIG welder and welded some small dots around the inside of the wheel to give the hubcap teeth something to bear against.
05-24-2009, 07:44 PM | #5 |
Get metal valve stems.Just a band aid,but would be safer.
